Question about ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775 Intel P45 Intel Motherboard
Motherboard is not going to self test mode - ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775 Intel P45 Intel Motherboard
Quickest way to check if motherboard has problems
If it makes it to the POST (Power-ON Self Test; before the windows/mac boot logo) screen, you're pretty close to golden. You could run a memory diagnostic (such as memtest86+) and/or prime95 in stress testing mode to see if the system is stable.
If the MOBO is bad, the computer, at the most, will sit at a blank screen (never getting to POST). 98% of the time it won't even turn on. Some have diagnostic beeps when booting to POST. If the computer originally had 1 short beep when turned on (when it was working), it may produce multiple short or long beeps. If it never beeped to begin with just disregard this.
The other alternative is manufacturer utilities. The computer or motherboard maker usually has a set of utilities to test the hardware. You'd be able to find it at their website in the support section.
There's a link at the bottom for more information about the POST operation.
Power on self test
May 03, 2016 | Computers & Internet
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
I have a 2006 ford fusion which the radio system
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna
  • Antenna cable
  • Door trim panel(s)
  • Speaker(s)
  • Noise suppression equipment
  • Smart junction box (SJB) fuse(s):
    • 12 (7.5A) (accessory delay feed)
    • 17 (20A) (subwoofer amplifier) (Audiophile)
    • 18 (20A) (audio unit hot at all times)
    • 22 (7.5A) (audio unit hot in START)
  • Battery junction box (BJB) fuse(s):
    • 20 (20A) (LH audio amplifier) (THX®)
    • 21 (20A) (RH audio amplifier) (THX®)
  • Circuitry
  • Digital signal processing (DSP) module (THX®)
  • Subwoofer amplifier (Audiophile)
  • Audio amplifier(s) (THX®)
  • Audio unit
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the audio unit, Go To Pinpoint Test A .
    • NOTE: Do not press any buttons on the audio unit while the audio unit is carrying out the self-test. System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the audio unit.
  1. If the DTCs retrieved are related to the concern, go to Audio Unit Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, and the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
NOTE: To enter the audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the key OFF or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has the following functions available:
    • Preset button 1 = On-Demand Self-Test. This button runs the on-demand self-test.
      • Pressing the MENU DOWN button allows scrolling of any DTCs found during the test while in this menu.
    • Preset button 2 = Display Continuous DTCs. This button enables viewing of any continuous DTCs that have been logged.
      • Pressing the MENU UP button allows scrolling of any DTCs while in this menu.
      • While continuous DTCs are being displayed, pressing the EJECT button will clear all present DTCs.
    • Preset button 3 = Signal Strength Test. This button displays the signal strength.
    • Preset button 4 = Software Version Display. This button displays the audio unit software version.
      • Pressing the MENU UP button allows scrolling of all audio subsystem software versions while in this menu.
    • Preset button 5 = Display Test. This test illuminates all the display segments for 5 seconds, then turns all segments off.
    • Preset button 6 = Configuration Status. This button enables audio unit configuration status.
      • Pressing the MENU button displays the ACM part number while in this menu.
  1. To exit the self-diagnostic mode, turn the audio unit off or turn the key OFF.
Feb 05, 2018 | Cars & Trucks
Stuck in self test mode
possibly bad ram memory
Feb 15, 2011 | Computers & Internet
My Escape Radio, CD, and Aux input will not work. My temp gauge works, but all music controls do not, except for the load and eject buttons for the CD player. I replaced three fuses that according to my...
Which three fuse's did you replace ? You should check for B+ voltage on both side's of the fuse . Two little metal tabs on top of the fuse. Voltage on both , fuse is good .
Try radio self-diagnostic mode .
A fluctuating AC voltage audio signal is sent to the speakers directly from the audio unit to reproduce sound. The audio unit has a self-diagnostic mode that can be entered by pressing preset buttons 3 and 6 simultaneously.
  • Audio unit
  • Antenna or antenna cable
  • Speaker mounting/speaker cones
  • Radio ignition interference capacitor, radio frequency interference suppression bond, or radio receiver hood bonding strap
    • 7 (10A)
    • 12 (5A)
    • 16 (15A)
    • 7 (40A)
    • 15 (20A) (Hybrid)
    • 16 (25A)
    • 21 (40A)
    • 22 (40A) (Hybrid)
    • 23 (40A) (Hybrid)
  • Circuitry
  • Audio unit
  1. If the concern is visually evident, GO to Symptom Chart .
  1. If the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
Speaker Walk-Around Test (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in the radio tuner mode (AM/FM).
  1. To enter the speaker walk-around test, simultaneously press the audio unit preset buttons 3 and 6.
  1. The speaker walk-around test stops at each speaker and applies sound to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR and SUBWOOFER.
  1. To exit the speaker walk-around test, turn the ignition switch off, turn the audio unit off, or press preset button 1 for diagnostics (DIA).
Audio Unit Self-Diagnostic Mode (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. The self-diagnostic mode has 6 manual tests available:
    • Preset button 1 = ENTER DIAGNOSTICS. This test enters diagnostics from the speaker walk-around test. Metrics are available with SEL and ON buttons indicating time played in AM/FM, media, number of buttons pressed, etc.
    • Preset button 2 = EEPROM BLOCK STATUS. This test shows the validity of memory to calibrate the clock, and seek sensitivity.
    • Preset button 3 = EXIT DIAGNOSTICS.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for its software configuration level.
    • Preset button 5 = DISPLAY TEST. This test lights all the display segments for five seconds and then turns all segments off.
    • Preset button 6 = RAM CONTENTS READOUT. To enter these tests, press preset button 1 while in the speaker walk-around test, then the desired preset button.
  1. To exit the self-diagnostic mode, turn the audio unit or the ignition switch off.
Oct 06, 2017 | 2008 Ford Escape
Have the machine in self test mode and dont know what each button
Just read your machine user manual.you will find detail info.about all the button.
NOTE: Do not skip ''self test". because during self test mode machine check it self & make sure that it is working properly.
Jun 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a toshiba satellite p305d-s8828 laptop and have 19dc @ plug going into main board and 19dc on motherboard. Is the motherboard fired? And no power on computer.
Since you have measured the voltage on the motherboard I must presume you are saying there is no power "indicator light" on computer. If this is not the case please clarify. If the light is absent please test the battery as these laptops are not designed to work without a battery or with a dead battery. Operating without a battery can spike the motherboard or other components and cause failure due to overvoltage. If you do have a power indicator light then next observe whether the bootup is proceeding with a beep after the POST (power on self test) and whether you can hear the movement of the hard disk drive... possibly indicating failed LCD display or display drivers/setup. Press F8 after the POST beep to get to safe mode display drivers.
Oct 07, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
Stereo not working, and slidind doors either. need fuse diagram
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
May 25, 2009 | 2002 Ford Windstar Cargo
Printer flashes self test
GO ON LINE AND TYPE THE FOLLOWINF INFORMATION IN THE ADDRESS BAR:
HP PSC 2175 ALL-IN-ONE INKJET PRINTER FLASHS SELF TEST MODE OVER AND OVER
ENTER
SEE IF ANYONE ELSE HAS EVERY SEEN THIS PROBLEM BEFORE
Mar 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775 Intel P45 Intel Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
