Question about Garden
Can not go down deep enough below the freeze line without hitting solid rock. Is there anything out there to insulate the line without costing me a fortune...
  • 604 Answers
When you say "insulate the line" I assume you mean water line. the only thing that you can do is to use "heat tape" and then over that you would place fiberglass insultation and silver tape to keep the insulation on the tubing. If you live in a climate that isn't too cold and has a short season, the built in thermostat on the heat tape will prevent it from "costing you a fortune" mobile home tubing is often insulated this way and its not very expensive to maintain an above freezing temp.
Posted on Mar 22, 2011
How to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
Nov 24, 2010 | Computers & Internet
Tip
How to uninstall deep freeze
To uninstall:
versions 6.X.
on Mar 15, 2010 | Computers & Internet
Yahoo.comHow to uninstall deep freeze 6 software from PC
Faronics Deep Freeze is a very powerful application, it prevents any unwanted changes on the system by freezing an entire hard disk or partition without restricting user access. Unlike older version, Deep Freeze 6 cannot be disabled or uninstall this Deep Freeze without password. Before u reformat or install a fresh OS, try the steps below, without password. 1. Boot yr PC from the CD with windows XP, if u have Windows XP OS 2. Now enter R to repair after booting. 3. Let it continue until finish 4. Now prepare the DeepFreeze to install, u will come across a option "Uninstall Deep Freeze", select this option and click next. After finishing the uninstall, reboot yr PC. 5. Now u will find that the Deep-freeze has removed from your computer.
Aug 25, 2010 | Computers & Internet
Remove deep freeze from computer
To uninstall:
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 19, 2010 | Computers & Internet
How to uninstall deep freeze from my pc
(Please let us know if you find the following has been useful.)
In order to uninstall it, you need to disable Deep Freeze first. To do that, please follow the steps below:
  1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
  3. If you have not yet entered a password you should be able to click OK without entering a password.
  4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
I hope this solves your issue. Regards.
The fridge is leaking inside. I guess the condensation line os clogged since the pan below has been dry for a long time. I do not know how to unclog the condensation line. Thanks Alfonos Socarras
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again
Jul 31, 2010 | Whirlpool Refrigerators
Char broil patio caddie, how many coals should it contain?
Your referring to the 'LAVA ROCK' which lines the botton grate. There should be enough to cover the grate 1 layer deep only.
Apr 27, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Samihullah
To uninstall:
Mar 15, 2010 | Sony VAIO PCV-W600G PC Desktop
Water leaking down from freezer
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER , solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Dec 09, 2009 | Whirlpool ET9FTKXK Top Freezer...
Freezer drain is full of water and freezes up and water ends up getting on floor. How can it be unplugged?
Remove the food from the freezer and ice maker ( if equipped ) . Remove the screws from the back panel , and remove the panel . Use a hair dryer , starting in the middle , below the coils , and defrost until you see the drain hole . Use hot water to help thaw the drain hole . Once water flows down , use a small hose inserted into the hole , and blow thru , to remove any debris accumulated in the drain line . Get a piece of ALUMINUM solid wire ( 14 - 16 guage ) about 9" long , completely stripped of insulation , and insert it into the hole as far as possible ( without force ) . Wrap the other end , about 1-2 turns around the black rod ( defrost heater ) just above the hole . When the refrig goes into defrost , the heat will transfer to the wire , keeping the drain hole from freezing up again .
Sep 13, 2009 | Whirlpool Refrigerators
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
