Question about ESQ Aston Stainless Steel Watch for Men
How to set dials on a aston gerard chronograph watch
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
Oct 09, 2012 | Invicta Lupah Collection Chronograph #9813...
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    How to change the hour
    on most watches, you can change the hour by twisting the crown... As I can see this is a chronograph watch, mostly divers use these kinds of watches. the two other buttons are to set the chronograph. As i do not know what brand this is but, try to play with it you will find out. Or take it to a watch professional.
    Jul 30, 2009 | TechnoMarine Dial Chronograph Watch
    Using the stop watch feature
    Dennis,
    "Chronograph" is watch terminology for 'stop-watch'.
    There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
    The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
    There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
    To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
    Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
    Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
    The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
    Dec 25, 2008 | Fossil CH2470 Watch
    How to set a Honora chronograph watch
    You have to upload here all details of the watch: model, ref. number. Movement number and good pic would be very helpfull.
    Dec 20, 2008 | Chase-Durer Typhon Chronograph White Dial...
    Sector 250 Chronograph Alarm
    the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
    pull the middle dial out to put it in alarm mode.
    To set alarm:
    -pull the center knob out.
    -with it out you can now use the bottom (right) knob to set the alarm.
    -pull the bottom right knob out one notch
    -turn the knob clockwise or counter clockwise to set the alarm time
    -push the knob back in (all the way)
    the alarm is now set
    if the center (right) knob is pulled out the alarm is ON
    if the center (right) knob is pushed in the alarm is OFF
    I have owned this watch for about 10 years now and love it.
    the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
    repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
    enjoy the watch!
    Dec 11, 2008 | Sector 2653940025 Wrist Watch
    Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
    1. Pull out the time set mode button.
    2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
    3. Press the time set button back into normal position.
    Oct 01, 2008 | Watches
    Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
    Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
    Sep 03, 2008 | Watches
    ESQ Aston Stainless Steel Watch for Men Logo
    225 people viewed this question
    Top ESQ Watches Experts
    Bill Boyd
    Are you an ESQ Watch Expert? Answer questions, earn points and help others
