Question about Car Audio & Video
Hi, my kid was playing with my remote starter and when i came to use use it, i couldn't turn on/off my car using the remote. i can lock and unlocked the doors. please help. joe
    Sniper:
  • 50 Answers
Hello.... sorry to hear you are having a problem. It sounds as if the system may be in valet mode. A lot of remote start systems have a feature like this to keep the car from starting. You can turn this mode on when you are having your vehicle serviced and it keeps the car from accidentally starting when a mechanic is working on the engine. It will still allow you to use the lock features but not the starter. If you will let me know the make and model of the system you are using I can research this for you. Also the make, model and year of the vehicle would be helpful as well. Hope this helps!
20 year car audio/video installer
Bay manager
Posted on Mar 22, 2011
The drivers side cook lock does not lock or unlock using the remote. The other door do respond to the remote. What is the cause and solution?
Hi Charles
The drivers side door gets the most use
Check the actuator wiring coming through the door hinge
If it works from the key then the Power to the door is OK & the key switch is ok. Must be trigger wire from wireless device receiver!
Good Luck
Hyundai Door Lock Actuator eBay
Hyundai Entourage Alarms Remote Car Starters Keyless Entry Locks
Jul 08, 2015 | 2008 Hyundai Entourage
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
Remote start work but door will not unlock or lock!
Do the doors unlock when the remote starter is not running? If so, then you to connect to a different set of door lock wires.I usually connect to the factory alarm and disarm wires in the driver kick panel. They are blue for arm and pink for disarm. You test them by turning the key in the drivers door.
Aug 18, 2012 | 991 Responder LC3 SST Security/Remote...
My alarm wont turn off. my car wont start. its a 2004 tiburon.
With alarm activated your ignition is disabled.Find the combination to disable it.With GM's you hold opposing buttons on the fob till it beeps twice. The dealer should help for no charge.
Feb 28, 2010 | 2004 Hyundai Tiburon
I just bought a car that came with two Pursuit PROOE4BS remote I can only get the remote starter to work but after the car starts2c if I enter and depress the brake2c the car will turn off Also I can27t...
if you enter the car after you used remote starter,dont depress your brake.you need to put your key(insert) into your igniton barrel
and turn it in to ON possition(dont crank the starter) now you can depress your brake to cancel the remote start.and your door lock and trunk maybe the installer didnt connect the wiring from remote starter to your car...
Feb 09, 2010 | 2004 Lexus ES 330
Dealer install remote starter bypasses kill switch
1) remote starter was not hooked up to the factory arm wire
2) trunk release was programmed to disarm factory alarm before popping trunk
3)parking light wire on remote starter was not hooked up
4)disarm wire from remote starter was not hooded up
5)this is not normal and they should fix the problem or have it done by some one else and have them pay for it, how much did they charge,
Bring it over I'll fix it right and not charge overpriced amount
Jan 11, 2009 | 2005 Hyundai Sonata
I have a 2006 G6 and the remote starter recently stopped working. The remote will lock and unlock the doors but when I hit the lock and then starter button on the remote the lights will just flash and you...
you can only start the car starter three time before pcm disables the function must start agin with key to get working. also may have diabled car starter by dic comands on radio also if you have engine light on will not operate car starter due to light.
Jan 02, 2009 | 2005 Pontiac G6
Remote starter does not work but will unlock and lock doors.
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Dec 08, 2008 | 2005 Pontiac G6
We have a 2007 Entourage and you cannot lock it with the car running. We installed a remote starter and it will not lock the doors when it is remotely started. Can this feature be disabled?
i think that this is to prevent you from locking your keys in the car with the engine running.
Some remote starters have a feature that when the car is running (and in park) you can hit the remote start button twice for one second each - then you can take the key out of the ignition and still have the car running.
At this point....if you would hit the 'lock' button on your door the doors would immediately unlock. However, if you get out of the car and close the door leaving it unlocked and then you hit the 'lock' on your original car remote the doors will lock and stay locked. So now the car is running the doors are locked and you have the keys in your hands. Then you can run into the store or house real quick with your car locked.
Once you come back, you hit 'unlock' on the original car remote. the doors will unlock - you can get it - and then before hitting the brake put the key in the ignition and turn it (dont crank it) as if you had when originally using the remote starter.
Maybe this will work for you.....
Oct 14, 2008 | 2007 Hyundai Entourage Limited Minivan
Car Audio & Video Logo
118 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
