I have a monitor on which shape of screen is distorted and buttons for adjustments not working,is any other way to fix up this problem
    Problem Solver:
  • 53 Answers
Using the display driver utility good idea.
Posted on Mar 22, 2011
I have a Windows 7 home premium computer using a 1280 720 screen resolution. This is the recommended settings and everything looks right, shapes aren't distorted and such. But i installed Service Pack...
try to auto adjust with your monitor if possible or try a different resolution to see what works better
beyond that you may wanna try to rollback your display adapter's driver
May 06, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have a new flat screen monitor, thats oblong in shape and my eyes are going nuts because its all stretched out and i want it square looking.how can i change it?
This is common with wide screens and the screen resolution needs to be adjusted to keep the correct aspect ratio.
My method, open MS Word - new document then Click on Insert - Picture - Autoshape and select a circle and place this shape in the document. Then if you wish to make the shape larger, then hold down the Shift key and drag the corner box to make the shape larger.
NOTE by holding down the Shift key, the circle will keep its shape and not distort.
Now Click on Control panel - Display - Settings and adjust the screen resolution and then view the Word doc with the circle, if it is not a perfect circle then, adjust the screen resolution again until you see a perfect circle. I suggest you start at the highest resolution that suits you and work down.
Mar 21, 2010 | Compaq Computers & Internet
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor screen shrinks!
The problem is due to under voltage.You may have an unstable power or your computer auto voltage regulator (AVR) is not doing its part..If not then you have a busted capacitor..resolder all capacitors and replace ruptured capacitors with same value and ratings..
Jul 19, 2009 | Computers & Internet
Page will not fill whole screen
hi
you haven't mentioned much about ur monitor but generally adjusting the screen resolution to different setting should resolve the problem
while also there are screen setting buttons on the monitor to adjust the size of the screen and others
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Dell Computers & Internet
Screen shrunk
Try using the 'degauss' option of your monitor. It should be in the on screen menu, or possibly a reserved button for it. If not, you may have the options in your menu for the monitor to adjust the shape of the screen manually, you'll just have to go through the menues carefully using the various buttons on your monitor. If nothing fixes it, I would just replace the unit, as repairing it would likely cost more than buying a new one.
May 07, 2009 | Compaq 7500 17" CRT Monitor
Acer monitor - horizontal distortion
try using a different refresh rate that may fix the problem
Mar 25, 2009 | Acer Computers & Internet
My screen has been rotate to the right.how can i fix it?
in the monitor there is a menu button.....if you press it you will get some options.....in that there is a option.....using that you can adjust it to the correct position.....try this...it will work 100%.....
Sep 20, 2008 | Toshiba Computers & Internet
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
