When I transfer documents to my advent vega I find them in the in the documents folder but when I try to open them I get the message application not available. Where do I go from here?.
  • 4,350 Answers
Well, I need more specifics to answer fully, but perhaps you moved WORD documents and have not installed the Office Suite on the new machine. The program that wants to be called when you try to open a document MUST be installed, or you get the message that you are receiving.
Posted on Mar 22, 2011
Testimonial: "Thats it Problem solved many thanks"
I downloaded (hotel giant 2 iso) the installation was successful but when i opened it it gave me Application load error 5:0000065434 i don't know what to make or open it please help
1 - Open a Command prompt using "Run as Administrator" (Start>All Programs>Accessories>Command prompt)
2 - at the prompt type: CD "C:\Program Files (x86)\steam\steamapps\common\"
3 - hit enter
4 - a new prompt will appear, showing the above path
5 - at the next prompt type the makelink command (described below)
Command:
mklink /d "Fallout New Vegas" "G:\games\Fallout New Vegas"
(*** "G:\games\Fallout new Vegas" is an example. You will want to put the correct path to your Fallout New Vegas install folder.)
6 - hit enter
7 - This should create the representation of a new folder in the "proper" steam directory. (If you were to open this folder, it should take you to the real "Fallout New Vegas" folder, wherever it actually resides.)
8 - You will need to re-create any shortcuts using the new "proper" path. (IE C:\Program Files (x86)\steam\steamapps\common\Fallout New Vegas\FalloutNVLauncher.exe)
Q & A
- What did I just do?
You created a Portal between two folders to make them capable of existing in the same time-space. (For lack of a better layman's description) Be wary, this may cause the release of exotic particles into a neighboring universe.
- Why did this work?
When the computer now tries to find Fallout it will go to the default directory, and find the "Fallout New Vegas" symbolic link (again represented as if the folder were actually there) and use it as a window to the actual install. The game will be fooled into thinking it's using the default install directory, when it is not.
- Why not just use a shortcut?
Because it won't work.
Jun 28, 2015 | SouthPeak Hotel Giant 2 - Windows for PC
How to send scanned documents abroad
Place your document in the scanner and choose a low resolution. Although scanners allow you to choose a high resolution, that feature is better suited for transferring photographs into your computer for editing. For documents, a resolution of 100 dpi (dots per inch) is a good choice.
Open your computer's Control Panel and select the "Scanners and Cameras" icon to open the scanner wizard. Follow the instructions to choose a location to save your scanned document. Create a new folder on your desktop, making it easy to locate the file later. Scan as many documents as needed to this folder.
Use your email account and create a new message, inserting your intended recipient's email address in the "Send to" field. You must type in the email address exactly.
Look at the top of your email window to find the "Insert" menu. When you click on it, a drop-down menu will appear, select the "Attach a File" option and choose the location of your document.
Highlight the desired document in the folder and double-click on it to attach it to your email message. Check to be sure the document attaches by looking for the file name in the "Attach" box above your text.
Repeat Steps 1 to 5 if you need to attach more documents. Send your email as usual.
Best of Luck!
Sep 06, 2011 | Computers & Internet
Everytime i open my Yahoo messenger it freezes my computer... what should i do?
Try a clean uninstall reinstall of Yahoo messenger.
Assuming that your Operating system is Windows XP. First go to Start>Control Panel> Add/Remove Programs
Select Yahoo Messenger & Click on Remove. Once it is completed, Open My Computer > Local Disk C:\Program Files\Yahoo! and delete this folder.
Delete the folders below if exists.
C:\Documents and Settings\Administrator\Local Settings\Application Data\Yahoo
C:\Documents and Settings\All Users\Application Data\Yahoo!
Then download the latest version from the Yahoo website and install it.
Hope this helps. Good Luck.
~SmokinJoe~
Aug 23, 2011 | Yahoo Messenger
I am trying to unistall elibrary software and i am getting an error message 1324 the path sony reader contains an invalid character
Hi!
You can try to manually remove the software and reinstall, BTW there is no operation system detailed. But here's a solution for windows XP, Vista and 7
Windows XP:
Open My Computer .
In the My Computer window, go to the following path
Delete the folder called "kinoma"
Then go to the following path:
C:\Documents and Settings\"your user name"\Local Settings\Application Data \
Delete the "Sony Corporation" folder
Windows Vista® and Windows® 7 operating system operating systems:
Open Computer on your Desktop
Go to the following path:
C:\ProgramData\
Now go to this path:
C:\Users\"your username"\AppData folder\Local\
Delete the folder called "Sony Corporation"
GoodLuck!
eBookBoy
http://digialreader.freeforums.org/
Jul 18, 2011 | Sony PRS-505 eBook Reader
Can't transfer photos from SD card to advent vega
you will need to connect your advent vega to your computer through a usb port and install it
once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually click start right click on my computer you should see your mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll through all of the devices if you see a yellow question or exclamation mark or a red x you will need to update the driver right click on the device to update driver
if your computer came with a motherboard disc the drivers could be on it
click start click on my computer to open from there you should see your camera then right click to open you should find the photos in there
click start all programs accessories open windows explorer navigate to your photos
right click on the photo
Jun 18, 2011 | Computers & Internet
In trying to download video from our cam corder (Sony DCR-SR85) to our PC we get the following message 'Document management information can not be located" and we are unable to download the video files....
Different ways to transfer video:
Transfer the video to the computer using one of the following methods:
Use the Import pictures and videos option.
    1. In the AutoPlay window, click Import Pictures and videos using Windows .
    2. In the Import Pictures and Videos window that appears, click Import Settings .
    3. In the Import Settings window, assign the location on the computer where you want to copy the picture and movie files.
      • Next to Import images to click the Browse button and then select the desired folder (for example, My Pictures ).
      • Next to Import videos to click the Browse button and then select the desired folder (for example, My Videos ).
    4. Click the OK button.
    5. In the Import Pictures and Videos dialog box, click the OK button.
    6. Click the Import button.
  • Use the supplied Handycam® Utility application.
    1. Start the Handycam Utility application bundled with the Sony® Picture Utility software.
    2. In the Handycam Utility window, click to the select the type of files you want to transfer: HD movies , SD movies or Pictures .
    3. Click the Import button.
  • Copy and paste the video files from the Removable Disk window that represents the camcorder.
    1. On the computer desktop, create a new folder.
    2. If the Removable Disc window is not showing, open the My Computer window and then click to select the Removable Disk icon.
    3. In the Removable Disk window, click to select all the folders and files listed.
    4. On the keyboard, press the CTRL+C keys to copy the folders and files.
    5. Open the new folder that you created.
    6. In the new folder, press the CTRL+V keys on the keyboard to paste the folders and files into the new folder.
    7. Rename the new folder.
Oct 21, 2010 | Cameras
I can't scan on my lexmark printer model x5650. When I scan a document it gives me the message " Install the OCR from the OCR folder". I can't find the OCR folder in my computer. What should I do".
The Lexmark OCR scan software is available in the installation disk that came with the printer. You can explore the installation disk and look for the Abby setup application in the OCR folder (for Windows). For Mac OS, right-click on the Install icon and choose Show Package Contents. Open Contents folder > open Package folder and manually install the Abby Finereader application.
However, if you don't have the installation disk, contact Lexmark technical support. Thanks.
Sep 30, 2010 | Lexmark X5470 All-In-One InkJet Printer
Reinstalled software and the old files are there but they do not
copy them to my documents/digital wave player/message/folder a
they will show up there
Mar 11, 2009 | Olympus VN-2100PC Digital Voice Recorder
I have lost my recovery disc supplied with my advent 7000 laptop can you help please
advent 7000 recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
  • There are two ways to start the recovery -
    • Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
    • In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
  • The recovery will load and display a box with one option:
    • Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
    To access the recovery options below that erase all data from the computer, click the Advanced button.
    • System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
    • System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
Nov 05, 2008 | Computers & Internet
51 Error
Have you tried repairing disk permissions? Go to the Utility folder in Applications and start up Disk Utility. Click on the second icon at the top left, then click on Repair Permissions. Repair Disk at the bottom far right will be grayed out.
If that does not correct the problem:
Quit AppleWorks.
Go to your user/Documents folder, and remove the AppleWorks User Data folder, put it in the trash, and empty the trash.
Do the same to your user/Library/Preferences/Appleworks folder
Do the same to the com.apple.appleworks.plist
logout and log back in as the same user. (not really necessary but I like an almost fresh start)
Open Appleworks, and make a NEW document and try to save it.
Open an existing document and try to save it.
If either of these will not work, let me know.
Aug 15, 2008 | Computers & Internet
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
