Question about LG 42LH30 42 in. LCD TV
How is the AW-47LG30M wall bracket attached to the 42LH30 TELEVISION?
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
My wall studs are wider than my television mount
Attach finished 1x4s to the two studs. Attach telelvision bracket to the 1x4.
Dec 28, 2008 | Samsung 46 in. LCD HDTV
Can i wall mount this
Usually, UMC include the screws already screwed into the wall mounting holes that you should use to attach a wall bracket. This is so you dont then go and use longer screws often supplied with wall mounts that are way too long and can damage the parts inside the TV.
Dec 18, 2008 | Toshiba 20HLV16 20 in. LCD Television
M3 mounting bracket securing pins
Polk in the US are sending me a replacement pin. What great guys they are.
Sep 23, 2008 | Polk Audio M3 Speaker
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
Hannspree Television/Wall Bracket
If there are six threaded holes in the rear of your TV and the bracket supplied has only four holes I would bet that the weight requires a heavier bracket.
Apr 03, 2017 | Hannspree Televison & Video
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
LG 42LH30 42 in. LCD TV Logo
1,038 people viewed this question
