Question about Whirlpool Duet GHW9150P Front Load Washer
The boot gasket on my duet washer has separated from the drum. The problem was caused when my wife attempted to clean a set of rugs. I am sure I can figure out how to replace the gasket but is it worth it?
  • 147 Answers
IT IS A LITTLE TRICKY BECAUSE YOU HAVE TO TAKE THE FRONT OFF TO REPALCE THE BOOT
Posted on Mar 22, 2011
My duet washer is leaking beacuse the seal is not aligned right, the metal ring that holds the seal in keeps popping ou..any advice?
Carefully pull the nozzle from the window washer tube. Separate the plastic gasket ring from the nozzle. Insert the nozzle through the hole in the boot and slide the plastic gasket ring down the shaft of the nozzle so that the boot is securely trapped between the gasket ring and the nozzle ridge. Insert the nozzle shaft into the window washer inlet tube and insert the end of the water inlet tube into the boot. Fit the boot around the front lip of the tub so it rests smoothly and evenly. Fit the boot clamp around the front lip of the tub and tighten the screw. Be careful not to over tighten this screw. Damage to the boot clamp or the boot could occur.
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello. It looks like the rim of the tub is
sounds like the rubber boot from door to drum is worn.  can be replaced but suggest a pro do it..
Jul 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell when starting a new load the next day
These are some good tips. However, leaving the door open between loads decreases odor by drying out the residue which can make the residue difficult to remove. Also, the residue will affect the next wash load.
The only way to have a truly clean washer is to remove the odor-causing residue. The "splash area" just 3-5 inches above the normal waterline is where the worst buildup is. To clean the whole tub use a washer cleaner that is able to be used with clothing in the washer. The added laundry will raise the water level to include the splash area.
There are many washer cleaners on the market. Some are all natural and can be used with laundry to safely clean inside the washing machine. After you get rid of odor you'll need to change your washing habits so it doesn't come back.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am dumb!...i washed a rug in the washer, and it caused a clog. The water wouldnt drain, but it would spin, and then act like it wanted to drain, start to spin again, click off and try to...
It is possible 1 or both drum springs have become unhooked, or the dampers have come ourt of the sockets.
You should be able to rehook the spring/s back , but it does require some effort.
Remove lower rear cover of washer to check the suspensions.
Apr 05, 2010 | Hotpoint Washing Machines
Washed a wool VERY linty rug and washer quit, won't spin, won't drain, won't run. Motor hums. Suspect scads of lint in trap. How to fix? We cannot locate the lint trap. Frigidaire front loader....
Sandy, What has happened is the peices from the rug have jammed into the agitator against the drum. This causes the agitator not to agitate and the drum has been jammed against the agitator. To fix this problem you will need to remove the agitator. Depending on how old the washer is is going to let you know how hard it will be to remove the agitator. The top of the agitator has a cap that will unscrew to the left. Once the cap is removed you will need to grab the base of the agitator at the 3-9 position and attempt to lift. This may come right up and you can remove the debris in the area and reinstall the oppisite of the above, however of the agitator does not come up easily you wiil need to get an appliance repairman out since he has the right tool for the job
Good luck hope this helped
Dave
Jan 14, 2010 | Frigidaire Washing Machines
Need bolts to stabilize washer for move
Dont know if you can purchase these. First people to try are the manufactures. Otherwise, unscrew the two screws at the rear top of machine and pull backwards to remove top.Then pack some towells or rugs around the drum then replace top. Don,t forget to remove rugs at new home.!! Good luck on your move.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front door gasket whirlpool duet washer
before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Banging while spinning and disintegrating gasket
Most likely not the drum bearing on this one.
I believe that your inner basket support has failed. It's a common problem on 4+ year old duet washers. This is by far the most labor intensive repair that can be done on the duet washer. You will need to tear down the machine for this repair. Expect it to be a four to eight hour job depending on your level of skill.
The basket is under lifetime warranty. The new basket will come w/the basket support already attached to it. Stupid as it sounds, You can't buy the bolt-on basket support alone, You need the entire basket! wtf?
The front section of the outer tub is supposed to have a 10yr warranty. Being that the tub was damaged by the basket, They may or may not warranty the parts.
Do a search on fixya. There is a guy from MA that has a complete set of pictures and info on the rotted/broken basket support.
Jan 02, 2009 | Whirlpool GHW9100L Front Load Washer
Cleaning the outside of washer Drum
hi there,
this is quite common for all front loading washers. the best way to clean is to use either Affresh or Washerfresh tables. you can purchase them at any appliance parts supplier.
Oct 11, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
164 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
