Question about Technics SCEH790 CD Shelf System
Hi I have a Technics SCEH790 CD Shelf System, plus a pre amp phono stage for my turntable, I have had this working in the past as it was a friend who whirerd it all together, I have moved my hi fi to a differant place and I dont know how to whire it back up again, turn table had a red and white jack plug whire coming out of it and I don't know what to plug it into on my Technics SCEH790 CD Shelf System so if you hav a pic of the back of your same hi fi so I can see where I need to plug mine into, Many thanks ****
  • Michael Brown
    Michael Brown Mar 22, 2011
    Hi thank you for your reply, sorry for being so thick but my preamp has a cable witch has 2 jack plugs on each end both have a red and white jack each end, do I plug both red in red and white in whits on hifi?, or are you saying I have just one to plug in? so just say red from preamp out to my white input on my hi fi? sorry again but I don't want to blow up my hi fi, Thanks again ****
    Brigadier General:
  • 8,546 Answers
PHONO PREamp. Does that suggest anything?
No picture necessary. YOU can see it. I can visualize.
Turntable to the Pre-amp IN. Preamp OUT to ANY available RCA input (usually AUX,).
Posted on Mar 22, 2011
  • David Dunn
    David Dunn Mar 22, 2011
    INs to OUTs means between different devices, not on the same device. Every output feeds an input somewhere else.
    Turntable OUT (the only direction it has) to the Pre-amp IN. Preamp OUT to ANY available RCA input ON THE RECEIVER (usually AUX).
    Nothing will blow up from the RCA cables. They're all low voltage, referred to as Line Level. The preamp takes Tuirntable cartridge level (very very small) and PREAMPLIFIES it to Line level for use by standard audio circuitry. It also messes with the frequency balance because the sound was severely changed to make it fit the grooves on the record. Google RIAA equalization. THAT is why PHONO only connects to PHONO. It is unique.
    Red and White are Right and Left, respectively of your turntable's cartridge is wired correctly. It's just color coding for YOU to use in wiring and to help you keep continuity throughout multiple devices. It's all academic anyway. Maybe you would prefer to have the guitars on the opposite side. If you want to hear both channels you will have to connect both cables from the source through every device.
Cannot hook up sound to surround sound , everything else works, cd player, radio, tapedeck. just the turntable does not work. any suggestions? deb
Hi, you need to connect the turntable to your amp via a phono input connection. If no phono input available then a pre amp needs to be used between turntable and amp to up the signal. Cheers John. Styluscity@gmail.com
Sep 28, 2011 | Technics SL-1200MK2 Turntable
I have a Technics Quartz SL-10 Direct Drive Automatic turntable and I need a pre-amp to drive it through a JVC RX-6012VSL Audio Control System.....preferably a Technics pre-amp.
Technics Preamps on eBay:
http://shop.ebay.com/i.html?_nkw=preamp+technics&_sacat=0&_odkw=preamp+technics&_osacat=0&_trksid=p3286.c0.m270.l1313&_rdc=1
There are, of course, many non-Technics PHONO preamps out there.
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
If you already have the central receiver and amplification part nailed down you really only need a Phono Preamp to boost and shape the output of the Phono Cartridge. Otherwise you're paying for source switching, volume and tones controls you don't need.
Mar 03, 2011 | Technics SL-DZ1200 Turntable
Connected to turn table. having sound problem. At 99, sound hardly audible.
The bose as most all in one systems do not have an inbuilt phono stage. Phono especially MM type have a very low signal and an eq curve that gets altered in the phono stage. Without a phono stage (known as a phon pre amp) you will not get much fun from your turntable. To connect : turntable out - into phono preamp - phono pre amp out into bose line in/aux in
Sep 28, 2010 | Bose Wave Music System CD Shelf System
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
Ipod input for sa-eh760
You can plug the Ipod into the mic input , to do test recording. But the result wont be great.
To listen the Ipod in your stereo you should plug the Ipod into the Auxiliary input on the stereo.
Naturally you do not need any dvd.
Here is the adapter: 1.5M 3.5mm Male to Male AV Audio RCA Y Adapter
Feb 17, 2009 | Technics SCEH790 CD Shelf System
No sound from my SCEH790 system from turntable...
Hi...
The aux wont work on a TT . You need a turntable pre-amp. Then you can plug it into the aux jacks.
Try partsexpress.com or mcmelectronics.com
Jan 11, 2009 | Technics SCEH790 CD Shelf System
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
Technics SCEH790 CD Shelf System Logo
152 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
