Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Refrig door makes a clicking noise when door reaches full open point - same noise when closing. Sort of like it is rubbing something. Tried lube but no difference. Just annoying.
    Problem Solver:
  • 53 Answers
Inside the bottom hinges small plastic bush may be broken.
Posted on Mar 22, 2011
Why does door squeak when opening or closing?
It is either the metal hinge points which can be silicone lubed or it is your seal rubbing on something which can be cleaned and should go away.
Aug 18, 2015 | Heartland Refrigerators
My Toyota Avalon passenger door makes a clicking noise when opening or closing. What could cause this?
if the click happens when the door is almost completely open then there is an over center cam that latches the door open so it doesnt just swing back at you .. the cam is visible near or on the door hinges ... if there is any loosness in the pivot pin then it will snap each time you go over the latch point .. heavy greese on its pivot pin might quiet it down .. if the click happens just as the door is opened then make sure the door front edge is not hitting the fender edge. of course lube the hinges and make sure they are not loose ...
Jul 04, 2010 | 2005 Toyota Avalon
Back door makes terrible squeaking noise when
When you open your door you will see a flat bar that slides into the door while opening and closing. It is located between the two door hinges. There is a rubber on the door where the flat bar slides in and out, remove that rubber and you will see little rollers in the door, those rollers need to be oiled, preferably with engine oil. Oil the rollers and work the doors back and forth, the noise should abate.
Feb 21, 2010 | 2005 GMC Envoy
It is a side-by-side, and difficult to open the doors, esp. the refrig. side after having opened and closed the freezer door.
Hi, this problem are what we called, vacuum (air) lock, it's not a problem, it means that your door are sealing properly, you should wait 2-4 mins, before opening, doors will open normally, if you give it 2-4 mins, if you try to open door immediately after closing, you will get that sort of vacuum lock, what you could do when it's lock, push something flat between door gasket and ref. body, try not to break gasket, you will hear air releasing, wait few seconds and door will open easily. it.s quite normally for ref. door to air lock, especially when you try to re-enter ref. immediately after closing. it will go away after a while, good luck.
Aug 10, 2009 | Refrigerators
Refrig door does not seal shut.
jack up the two front leveling feet a bit to make it lean towards the back. or put a level on it to see how far it is off.
Dec 04, 2017 | KitchenAid Superba Architect KSCS25IN Side...
Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
Mar 16, 2009 | 2000 Honda Odyssey
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer door opens When you close refir. door
The freezer door is relatively light weight, and when the fresh foods door closes, the air has to go somewhere and the easiest escape route is to momentarily pop the freezer door open. The door should close again quickly. If is does not, make sure the freezer door liner is not touching the top or bottom, causing dragging resistance, and make sure that the front leveling legs are raised up so the door closes by it's self when released from a 45 degree opening. Sometimes the hinge side gasket rubs and holds things up also, especially if that area was cleaned. If that is the case, rub a film of wax on the hinge side gasket to lubricate it. Additional weight in the freezer door will also help.
Oct 27, 2008 | GE Profile Arctica Stainless Steel Top...
My automatic door on my van starts to close then when it is almost closed it automatically reopens without closing. I have looked and nothing is blocking it from closing.
Take a rag with rubbing alcohol and start wiping out all the creavas. Get it spick and span, those dern things are super sensitive a little peice of popcorn kernal will not let it close
Jul 29, 2008 | 2000 Nissan Quest
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
103 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
