Question about JVC Televison & Video
I own a JVC LT-26A61SJ LCD TV. The remote control works intermittently, sometimes switching the TV On/Off and other times not doing so (This situation is the same when using my Sky Remote control, set up to operate the JVC). This is a recent problems as all has been OK until a couple of days ago. Any Ideas? Is there a RESET for the TV.
Slinteriors
  • 8617 Answers
SOURCE: I have a Pioneer SD
the power supply will need to be trouble shooted. Check out this site they can help you and get you a service manual and free tech support.
http://servicemanuals.vstore.ca/
Posted on Apr 27, 2008
ginko
  • 19396 Answers
SOURCE: I have a problem with
What is the problem in detail.
Posted on Aug 04, 2008
SOURCE: Sky remote setup codes
your code is 1239
Posted on Aug 18, 2008
rylee_smith
  • 8619 Answers
SOURCE: sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Posted on Apr 26, 2009
tvtek
  • 1284 Answers
SOURCE: Problem with remotes for our zenith e44w46lcd tv
It could be that the main board or the remote reciever is bad on the TV. The best thing to do at this point is to have a technician verify which one is causing the issue. Otheriwise it would be an expensive gamble to replace both boards. Please take a moment to rate my answer. Thanks..
Posted on Nov 25, 2009
JVC LT-32N310a screen locked
Most of the universal remote controls will not work with all the functions to TV, whatever the brand they be. It will be best buy an original remote control. Contact the Authorized service centre for JVC to get an original one.
Jul 05, 2013 | Televison & Video
Tip
JVC LT-26X575 LCD TV Manual Download
Download JVC LT-26X575 LCD TV Manual
Would you like to review the features of the JVC LT-26X575 LCD TV ?
Have you lost your JVC LT-26X575 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC LT-26X575 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC LT-26X575 LCD TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | JVC LT-26X575 26 in. LCD HDTV
Tip
JVC LT-26X585 LCD TV Manual Download
Download JVC LT-26X585 LCD TV Manual
Would you like to review the features of the JVC LT-26X585 LCD TV ?
Have you lost your JVC LT-26X585 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC LT-26X585 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC LT-26X585 LCD TV documentation.
I hope that helps.
on Jul 03, 2010 | JVC LT-26X585 26 in. HDTV-Ready LCD...
JVC LT-42P300 Remote Codes
What remote? It depends on the remote. Different remotes use different codes. They all have a code search function that you can use to find the code.
Sep 19, 2009 | JVC LT-42X579 42 in. LCD TV
REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
May 27, 2009 | JVC LT-26X575 26 in. LCD HDTV
Tip
JVC LT-32X585 LCD TV Manual Download
Download JVC LT-32X585 LCD TV Manual
Would you like to review the features of the JVC LT-32X585 LCD TV ?
Have you lost your JVC LT-32X585 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC LT-32X585 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC LT-32X585 LCD TV documentation.
I hope that helps.
on Jun 29, 2010 | JVC LT-32X585 32 in. HDTV-Ready LCD...
Remote control (i hope)
The IR sensor in the tv is probably weak, you could make a mountain out of a mole hill and get it replaced (using your friends receipt ^_^) but there's nothing to be done about the sensor.
Feb 05, 2009 | JVC LT-32P679 32 in. LCD TV
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Blue light
2)wait 10 sec
4)wait 30 sec
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
