Question about Ricoh Office Equipment & Supplies
Our Ricoh Aficio 2020 is jamming on the right side and the paper gets caught in the black ? inside the right side door. ???
  • santosj27
    santosj27 Mar 22, 2011
    Try to give more details
Had a paper jam and now can't get door to shut
If you're talking about the duplexer door not shutting after the paper jam, check if the transfer roller has fallen off into the printer which is preventing the door from closing.
Mar 12, 2014 | Ricoh Aficio Mp-C300 Color Copier
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
I am having a problem with the ricoh aficio mp 1600L printer. It shows message"Follow instrctns in the right cover to remove". We have checked everywhere there is not paper jam. We are very...
ok mate. when you open the right cover, there is a registration roller on the side. the registration roller is black one. it is visible from the side. rotate that roller and the paper should come up. rotate that roller with hand.there is a small piece of paper stuck below that registration roller which is not visible.
Nov 26, 2010 | Ricoh Aficio MP 1600L Black and White...
I need aficio af 2020 software and driver to download
To download the driver for Ricoh Aficio 2020 follow these .steps :
1. Go to the link below
Driver download for Ricoh Aficio 2020
2. Select your operating system from the given list.
3. Download the required driver software.
Nov 17, 2010 | Ricoh Aficio 2020 All-In-One Laser Printer
Remove paper from adf error ricoh aficio 2020
Clean the paper sensors and move the actuators.Open and close front door to reset malfunction.
Jul 31, 2009 | Ricoh Aficio 2020 All-In-One Laser Printer
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Ricoh aficio 150 paper jam
There are pressure release levers on the fuser --- if they are not in the correct position they will not apply the proper pressure and you will get jamming in that area. The levers are either a light green, light blue or plain black. They should be on the left and right side ( looking in at the fuser. Turn/ flip them and check.
Dec 02, 2008 | Office Equipment & Supplies
Ricoh 2015 printer
The B is saying there is a jam in the right hand side of the machine. You may have fuser stripper fingers popped out of place causing it to jam or you may have a torn off piece of paper stuck between the registration rollers. Try spinning the black and silver rollers by hand and see if any paper comes out.
Oct 09, 2007 | Ricoh Aficio 2015 Copier
73 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
