Question about Vacuums
When trying to use shop vac for suction, at the same time the space for blowing is operating. how do i stop this blowing process so i can use it as a vacuum?
I have the same problem! Did you find a solution?
Posted on Nov 07, 2011
    Sergeant:
  • 259 Answers
On the shop vac there should be 2 places to insert the hose. One for blowing air and the other for suction.
Posted on Mar 22, 2011
  • jonmiguelsca Mar 22, 2011
    yes, i know there are two openings. but when i want to use the suction part, the blower part is blowing out the dust simultaniously. how do i stop the blowing opening.
  • janicemthoma
    janicemthoma Jul 25, 2012
    My best guess is that a cap for the hole not in use has fallen off. On my vacuum, there are threads for the cap. I have the same problem and no idea what happened to the cap.
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
connect the hose on the other end where it say vacuum not blow.
Sep 19, 2016 | Shop Vac Vacuums
How do I get my Shop Vac to suction instead of blowing?
Unlatch and remove the cover, then reseat it and latch it to restore suction.
Feb 05, 2015 | Shop Vac Vacuums
What do I do when there is no suction. My central vac just stopped picking up and though I emptied the machine and replaced the filter there continues to be no suction.
1. If it's an older model, the hose is likely well worn and probably has leaks at each end where it attaches to the handle and connector at the other end. If this is the case, a new hose is needed.
2. A blockage in the hose. To check the hose for blockages, detach both ends and drop a coin down one end. Lift the hose a little at a time so coin drops out the other end. If it doesn't, there's a clog. Please don't try to take it apart to remove the clog. If you can't get it out, take it to a reputable vacuum repair shop and let them.
best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked
3. Is there suction at the end of the hose, or is it just at the power nozzle there's none. If the hose has good suction, check the power nozzle airway. If it's blocked it can easily be cleared by pushing the clog back toward the brush with the handle of a wooden spoon, or other similar object.
Jan 15, 2011 | Electrolux Pu3650 Central System Vacuum
I have cleaned out the vac and changed the filter but I can hardly **** up leave on the garage floo.
Try this:
Detach hose, turn on vacuum, hold hand in front of intake to check airflow/suction. If it seems good, you either have a clog in the hose, are bad leakage.
If it's a clog, try placing end of hose in the exhaust port, turn on machine, and blow clog free. You may need to place other end into intake. This should clear it.
If hose is cracked, punctured, or smashed/collapsed, replacement will be necessary.
If there's not much suction at the intake, it may be time to replace your vacuum, or at least the motor.
Nov 13, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
Seems to have proper suction but dirt is not reaching the bag? I have checked all the hoses and there is no blockage.
There may be a blockage on the inside of the vac. I have had this happen to me a couple of times. The first thing I try to do is to make sure the beater brush is turning. If it isn't turning the dirt will not go into the bag. The other thing to do is to take a shop vac or something similar with high suction and see if you can suction out your hose. There may be something so high up in it that you can't see it. The last thing I would try is to take apart the inside where the hose connects to the bag and make sure that nothing is up in there. Try the shop vac first....this has always worked for me.
Good luck.
Aug 06, 2009 | Vacuums
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Stop vacuum from blowing to suction
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559995
Generic problem for all Vacuums
Posted by keyerica74 on Apr 30, 2008
Stop vacuum from blowing to suction…..
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You’re vacuum is blowing because your (round vacuum) belt is on backwards and is blowing instead of having suction – please reverse the belt and most vacuums have a diagram on the bottom of the vacuum to tell you which way to install. Not knowing the brand name or model #, if you have Questions, Contact you local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Kirby G 6 but it only blows air out, no suction. Also how do you detach the cloth bag to wash it?
I have the solution for the cloth bag laundering process...
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEA...
It should be helpful. :0)
The Tech Drive problem SHOULD be able to be fixed easily and fairly cheaply by a vac shop or Kirby distributor. There is an adjustment that needs to be made, but it shouldn't require purchasing any parts.
Marci
Nov 17, 2007 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
246 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
