Question about TC Electronic G-Major 2
When i hook up through the loop on my marshall head, connecting cables are being fried.
  • TC Electronic Master
  • 5,603 Answers
If you are frying cables that is bad! This means you have a bad ground loop.
IF that is an old Marshall head that doesn't have a three wire (with ground pin) power cord on it, take it in immediately to have a three wire grounding cord on it before you fry yourself and not just cables. Their old technique of having a switch to change to create a pseudo ground was stupid and VERY dangerous !
You can severely damage equipment due to bad grounds.
ALWAYS connect all interconnected electronics to the same power source or receeptacle.
Posted on Mar 22, 2011
Not very loud
Try inserting a patch cable(or any 1/4" to 1/4" cord) into the effects loop jacks on the rear of the amp. If that helps you have a dirty or bad jack. A little WD-40 works wonders on corroded/dirty jacks.
Apr 19, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
Can some one tell me how to hook up my half stack.
Using a speaker cable, plug head 16 ohm output to cab 16 ohm input, making sure the cab switch is set to mono if it's a stereo cab (1960)
Oct 01, 2013 | Marshall Amplification Marshall JVM410H...
Can i connect 2 (2x12) cabs rated @ 4ohms each to my avt50 head?
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp.
Feb 12, 2013 | Marshall Amplification Music
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp. Your only option would be to rewire your cabs internally to 16 ohms each by connecting the speakers in parallel, but that would cut your amp's power in half.
I have a marshall jcm 900 slx 100 watt head and 1960a cab, when i went to use my amp i got no signal from my guitar. none of the fuses had blown and there was still a hum coming through the speakers. I...
It sounds like you have a dead guitar cable or the preamp section of the amp is blown. It needs to go to the shop. It's way cheaper in the long run to just take an amp in. If you try poking around without knowing what you're doing you can fry something more expensive or worse yet yourself! There are leathal voltages in a guitar amp!
Aug 17, 2017 | Music
Hi. I've had this transistor Marshall head for about a year now but lately whenever I plug a patch cord in the input jack and turn the amp on, I get crazy amount of distortion. I know this only a problem...
A educated guess points to either broken soldering or a broken ground on the input jack itself. This is a CHRONIC problem of amps because people trip over the cord and it yanks the cable and jack sideways breaking it or the solder where it attaches to the circuitry.
To avoid the problem, loop your cable through the handle of the amp so when cable is yanked it doesn't yank the jack so hard.
Nov 16, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
How to connect the speaker cabinet to the head?
Use a SPEAKER RATED cable which will have good quality 1/4 inch jacks. Go from a speaker out on the head to one of the jacks provided on the speaker cabinet. NOTE: some newer speaker cabinets use SPEAKON connectors and if those are provided, they are more secure than 1/4 inch plugs/jacks.
PLEASE loop the speaker cables through a handle of the cabinet at each end to avoid them being yanked out while hot as the amplifier can be damaged if it happens.
OBSERVE the maximum load. If the amp says 4 ohms minimum, put no more than two 8 ohm cabinets on the amp as two 8 ohms parallel to 4 ohms.
DO NOT use an instrument cable.
Jun 13, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Bad Humm out
First disconnect all inputs. If hum is still there, PROBABLY the filter capacitors have gone bad. Replacement is the cure.
IF there is no hum without any inpout cable connected, there is a ground loop and either the ground at the inout connector is broken, or your cables and guitar may have a problem.
Nov 15, 2009 | Marshall Amplification Marshall MG250DFX...
Speaker was connected to effects loop when turned on now it does not work.
If you only connected the peaker to the wrong connector USUALLY no damage was done. SOMETIMES the effects loop jack which has a switch contact on it MAY not connect again when you removed the speaker connector. Some of these have very weak jacks Try putting a cable into the jack several times and removing to cycle the contact to possibly clean it. The other possibility is if you didn't have a speaker load you might have popped the power amplifier... hope not...
You MAY have to take this to a shop to repair this.
Jul 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
TC Electronic G-Major 2 Logo
288 people viewed this question
Top TC Electronic Music Experts
Michial Gueffroy
Tom Chichester
Seanzilla
Are you a TC Electronic Music Expert? Answer questions, earn points and help others
