When you plug it in to computer no lights come on cant turn it on no power
  • 77 Answers
Could be a problem with the cable or power supply.
Posted on Mar 22, 2011
Cant get monitor to go on
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Dec 24, 2013 | ViewSonic VA2012WB Monitor
Flashing green light on graphics card and power wont turn on
a green light ain't nothing wrong with, red it probs with the card.
So in fact this has noting to do with your graphic card.... It's your motherboard.
Can you remove your graphic card and plug your screen in the onboard plug,. I forgot to tell to turn off power , before you begin. So not only turn off the powerswitch, then there's still current, pull out the powerplug, remove your asuscard and plug in a manual pcboard and manual mouse. If done, tell me what happens when you boot, nothing. are you able to use bios????
Nov 12, 2012 | ASUS Directcu Ii Top Geforce Gtx 560 Ti...
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
I cant hear anything on my computer(cant get the volume working) jus got brand new computer 2day, mayb not plugged up properly, need help
there is 3 small circular sockets on the back of your pc they are coloured pink, light green and green or black plug your speakers into the light green one if that doesnt work try the other sockets one of them should work and dont forget to turn on the speakers usually the power button is on one of them...or if you dont have speakers try plugging the cable with the light green on both ends one end into the back of pc and the other end into the back of screen you might have to locate it where you see the connection cable on back of screen it might be hidden up under that part of screen ...good luck hope this helps
Sep 24, 2010 | Computers & Internet
My notebook refuses to turn on, i've switch outlets, double check that all connections are curretly connected, I've taken the battery off waited a few then put it back on - but still nothing, it just wont...
There are a few possible causes.
  • Your computer is coming on, but your screen is out and you just cant tell. You should see light come on and hear a few noises from the cd drive and hard drive.
  • Your power supply is bad (the corded thinggy)
  • Your battery is bad and has damaged the cord too.
  • The plug in the back of the computer is damaged (Possibly from a bad battery melting the connector)
  • You computer has lightning/surge damage and is just broken
  • The motherboard has failed completely
First, test the simple things.
  1. Remove your battery and try to start with only the cord.
  2. Check the plug that the power supply plugs into. Is it loose does it wiggle? It may need replaced/repaired
  3. Plug the power cord back in and wiggle do any of the light flicker? This may confirm step 2.
  4. Take your computer to a simple repair shop and see if they have a power supply you can try. REMOVE your battery first. If it works, great! Get the power supply.
  5. If none of these are the problem, leave the computer at the repair place for them to look at. There are a few other problems, but you probably cant check those yourself.
Jan 24, 2010 | Gateway M285-E Notebook
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
Replaced mother board, forgot where power switch plugs into
you can look for the power switch terminal by its label.like PW for power button and PLED for power led.reset is RS.
May 20, 2009 | E-Machines eMachines Desktop PC
Laptop will not turn on.
plug it into the wall , most newer laptops will have a power boost while plugged into AC.
check your power cable receptical on the back of the laptop, these are notorious for getting loose.
check the cable on the ac adaptor, these are bad for getting breaks that you cant see in them (run your hand down the cable physically and fell for any breaks while unplugged, then do it again plugged in and watch for lights to flicker on the computer.
look for the power light on the laptop to come on when you plug the adaptor in. if you get a light on the adaptor and on the computer, then the adaptor isnt the issue.
the next step is checking the power button and power supply.. post what your results are here and we'll move to the next step if not resolved.
Regards!
Oct 29, 2008 | Gateway Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
