Question about Ovens
My maytag oven is taking forever to come up to temp....worked fine yesterday.....stove top is working fine
  • ssaunta Mar 22, 2011
    apparently it needs a new bottom coil....I was assuming but wanted to be sure...Thank you for your help
  • Ovens Master
  • 19,396 Answers
Hi.
The problem is likely a defective temperature probe, first check the following.
Try disconnecting power for two minutes, disconnect power cord or trip the circuit breaker. That will reset the electronics.
Check if the problem happens with both broiling and baking. If the problem is only with one of the two functions, then one of the elements (electric oven), or a valve coil or igniter (gas oven) may be faulty and causing the problem.
If the problem occurs with both baking and broiling, then it is usually the sensor probe. The temperature sensor is located inside the oven cavity, and held by one or two screws. The sensor can be tested reading Ohms at its terminal with a multimeter. A bad sensor is often open at room temp (it reads infinite Ohms). A good sensor will read about 1KOhms at room.
Here you find parts and diagrams for most units. Enter the full model number as printed in the service tag.
Regards.
Ginko.
Posted on Mar 22, 2011
Model MET8775XS00; oven temp control not working properly. Lower oven take too long to heat up & temp calibration per manual does not work. Temp control is very erratic. Suggestions?
What is the age factor on the stove? You may want to get someone to come in and check it out, as it puts out some very high current. Stoves run on 220--240 volts, and the oven jacks up the Amps, which is a hazard if you make contact on them.
You can get a voltmeter and test the wall outlet for the power being put out. Sometimes if the wiring in the house has a bad line, it can't get enough to work.
Also, if you have a breaker box, you can test it to see if it has a dual electrical breaker for the 220-240 line.
If the stove is getting the proper power supply, then it could need fuses/breakers in the stove itself. How does the cooking plates on top work? The oven may have some elements that need replaced, but it may be cheaper to purchase another stove.
Dec 04, 2017 | Ovens
Problem with Maytag oven
Sounds like it may be the igniter failing
Feb 13, 2014 | Maytag Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
Ovens Logo
132 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
