Question about NRS Samsung Bd-3000s Deluxe Blood Pressure Monitor $70
When replacing monitor with new batteries the unit powers up ok but it counts up to around 40 and the battery symbol comes on. Batteries are installed correctly
    Brigadier General:
  • 4,736 Answers
The batteries you used as replacements may be to weak. Try replacing the batteries again, with new ones out of a currently dated package.
Posted on Mar 22, 2011
NEW Degen DE1103 radio won't run on batteries.
check the aa batteries in use as most radios do not run well on rechargeable batteries
contact the seller and ask how to get a new unit under warranty
are the batteries connected in the correct order
Apr 09, 2016 | Computers & Internet
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
What is the best way to store the new ryobi 18v battery
Is your ryobi 18V battery is a Li-ion battery? if so you can store it with 40% power and keep it clean, cool, and dry. Then every 1-2 month to charge and discharge the battery for once time.
More battery tips or batteries and chargers for cordless tool you can come here:
Cordless Drill Batteries Replacement Cordless Power Tool Batteries...
Nov 02, 2014 | Drills
How do I install the batteries correctly in a Stanley TimerMax Daily digital timer (Model #28441)
Battery holder should have + sign.
Then Reset timer.
If new batteries and reset do not restore functionality, then replace timer?
manuals on link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#31217
Gene
Sep 26, 2014 | Hardware & Accessories
Why won't my Parent Monitors work on battery power using new batteries, but will work fine on AC power?
Always be sure the batteries are charged and suited for your device.
Check contacts of the batteries and in the battery compartment of your device. Dirty or oxidised contacts can be cleaned with a dry cloth, or a cotton swap. Never use sharp tools to clean contacts or anything in or on electronic equipment.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Jul 27, 2014 | Safety 1st Baby Monitor
I WOULD LIKE TO BUY A NEWPowerware 9330-40kva UPS UNIT, COPLETE WITH BATTERIES .how much would that cost?
It's unlikely that you will be able to get a new one. The 9330 was discontinued many years ago though Eaton continues to service these models and provide replacement parts/batteries. I suggest that you call 800-356-5794 to see if Eaton has a partner that has any complete systems still in stock or in service inventory. The new UPS units are the 9355 and the 9390: www.eaton.com/9355 and www.eaton.com/9390 These new units are more compact, are more energy efficient and incorporate more advanced technology for monitoring and communication.
Mar 11, 2011 | Powerware 9330 40 (A40401110031112) UPS...
The light won't come on to charge the batteries. Last year we put non rechargable batteries in and the batteries melted and the acid seeped into the unit. Can I fix the unit?
If you had that much of a problem then you may be dealing with damaged parts from the overload and even damaged ciruitboards from the acid. Yes you could possibly fix it but you are talking about a few hours of playing around and you need the proper equipment ie meters, a scope, and a soldering station. Some of these are simple inside but the better ones can be quite complicated if they monitor things during the charge cycle.
These are not that expensive. Find a sale and replace it. Think of it this way if you paid yourself minimum wage for a couple of hours is that close to what a new one costs?
Apr 23, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
TI-83 PLUS
Most likely your battery is dying.
You can replace by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 06, 2008 | Texas Instruments TI-30XA Calculator
Technical problem
I purchased a *ist DS used a couple of weeks ago, and it turns out to have similar problems. This camera seems very fussy about batteries. I am using rechargeable NiMh AAs. After about 30-40 exposures, the camera shows battery depleted. If I turn the camera off, then back on, it will show a charge - sometimes a full charge and will work for another 20 or so exposures. It can keep this up for a couple of days.
I read an explanation in one of the photo blogs (can't remember which) that suggested this was caused by one or two incompletely charged batteries in set of 4. If one is discharged the current from the others supposedly will flow to it, giving fluctuating power readings to the power management curcuit. This sounded plausible enough that I purchased a new charger yesterday which monitors the charge on each battery. Too early to tell whether this solved the problem or not. The other option is to switch to disposable batteries.
Oct 09, 2006 | Pentax *ist DS Digital Camera
NRS Samsung Bd-3000s Deluxe Blood Pressure Monitor $70 Logo
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
