Question about IBM TravelStar 40GN 40 GB Hard Drive
I am having a problem with IBM travelstar 2.0 USB in which i just removed it from my loptop computer and re-use it again thru my loptop but it doesnt recognize my IBM travelstar and i tried to put into another loptop but still it doesn;t work now. can my IBM travelstar can be repaired or can work again or if may files can be retrieve.
4 Suggested Answers
  • 82 Answers
SOURCE: getting files off an old IBM TravelStar 20 GB Hard Drive
You can buy an adaptor that will connect your hard drive to a pc.
Ribbon cable from your secondary drive on pc goes into the adapator. Adaptor also coonects to laptop harddrive.
You also need to change from being a master driveto be a slave drive . see linkbelow.
http://www.hgst.com/hdd/support/tva/tvajum.htm
You can then copy file to pc a usb memory stick.
Posted on Oct 13, 2008
SOURCE: Cannot Open when connected
I connect harddrive IBM Travelstar 20 GB Model IC25N020ATCS04-0 (made in Thailand) to PC via USB port but cannot open ,LED is light .How can I do , I have no driver.Pls. help me.
Posted on Jul 19, 2008
flapjack937
  • 129 Answers
SOURCE: WESTERN DIGITAL CAVIAR SE 500 GB
Hi, looks like your usb drive has died. Try it on another pc / laptop first. If it still does not work, you will need to purchase drive data reader while will allow you to access the data. Most pc stores carry them. Cost about 50 euros. Best of luck.
Posted on Jul 20, 2008
I need a new a new cable (fits an unusual 5-pin socket) for an ibm travelstar external hard drive
the dearlership should know what you need. the reason the socket is so different is to let you know, the stuff in which contained in this part is very sensitive and could major problems if you are not sure what your doing
Apr 13, 2012 | IBM TravelStar 40GN 20 GB Hard Drive
Hi, I have one IBM Travelstar USB 2.0 external hard, suddenly now it is not deducting and the light which is there in USB device, some time it is green and red alternatively.. Pls help to resolve this...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jun 06, 2011 | IBM TravelStar 40GN 40 GB Hard Drive
..pls teach me how to
You need to purchase Windows Vista, once you have the disc with you, then you can start the Widnows installation process. during the process you can choose to format your hard drive and install Windows.
Feb 28, 2011 | IBM TravelStar 40GN 40 GB Hard Drive
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Dec 11, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
IBM Travelstar hard drive
The IBM webite will have the software located under the support link. You will need to lookup your specific model # and then the files will appear. Download and install those that you need. Hope this helps.
Jul 11, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Dell laptop with no cdrom and travelstar HDD
In this case you would have to...
1) preformat the drive
2) make it bootable in DOS
3) copy the CD contents to the drive
4) boot the target computer with the drive and run WINNT.EXE in the I386 directory to start the install.
*OR*
2) copy the CD contents to the drive.
3) put the drive in the target computer and boot it from a DOS bootable floppy.
4) run WINNT.EXE in the I386 directory to start the install.
Jun 26, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
Jun 01, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
IBM TravelStar 40GN 40 GB Hard Drive Logo
154 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
