Question about Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard
D815EEA2 - No Display But Pc Running Just Try It Bios Update intel.com Site.If You problem Solution ? So Please Help Me................
  • 961 Answers
Try shutdown computer using switch on tower. Restart in "safe mode". Window will pop up and click on "what is system restore", click on that. Another window will pop up, scroll down to "start safe mode", This will take a minute or two. A window will come up and click start or ok. The system will restore back, shut down and restart. Hope this helps.
Posted on Mar 22, 2011
Gateway 5300S Desktop PC - need original BIOS
Hello you can try one of the bios file from here as it is a INTEL mainboard:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+915+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D915GAG
Try one of the preversions. Your current bios file could be damaged.
Download the exe file so you can update the bios while the system is running.Don`t use unautorized programs to upgrade the bios it could go very wrong.
I could not find the original bios file.
Have you entered a wrong model ?
Here is the gateway support site:
http://support.gateway.com/product/?cmpid=supportnav
If you find the model here please unzip the file before you go any further.
And be 100% sure its the right model.
Hope this will help you
Nov 13, 2012 | Computers & Internet
D815EEA2 Bios Update setup mistake other bios but pc running so display can not show..........please Help Me then bios recovery & problem Solution
Download the bios here at intel:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22D815EEA2%22
Save the BIN file on a usb disk or a diskette
and let the pc boot from it.
Follow the instructons on the screen.
You need to reenter the boot settings in the bios
the clock and the harddrive settings etc.
Hope this will help you.
Mar 22, 2011 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
I need intel d815eea2 audio driver
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Dec 14, 2010 | Intel Desktop Board D815EEA2 Universal...
When i start my pc it make two beep sounds. And the other problem is, in the booting time it doesnot take any files from cd. My computers conifiguretion is intel d815eea2 board intel p3 processor...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 04, 2010 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Intel Desktop Board D815EEA2 boot problem
Hi and welcome to Fixya!
this means that the BIOS is corrupt ..
Thanks for using FixYa!
Jul 18, 2009 | Intel Desktop Board D815EEA2 Universal...
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
NO DISPLAY , BIOS DAED, HOW TO FLASH IT HELP ME . . .
Intel's web site for D845GLVA, click on the link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=947&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
The site above includes Bios files, drivers & manual.
Intel's Instructions sites;
BIOS Update Instructions for Intel® Desktop Boards
http://downloadmirror.intel.com/10506/ENG/BIOS%20Update%20Readme.pdf
Intel D845GLVA
Desktop Boards, Bios update instructions.
http://support.intel.com/support/motherboards/desktop/sb/CS-022312.htm
The .html site has video you can watch.
Mike
May 03, 2009 | Intel Desktop Board D845GLVA...
I want to update my display adapter driver
You should be able to update all drivers/software for your board at the Intel website under the support section. All you will need to do is lookup your specific board model # and it will give you a list of all bios & driver files available for it. Hope this helps & please rate this solution fixya. Thanks.
Feb 05, 2009 | Intel D915GAG Socket 775 Motherboard -...
Leave the connection to graphics card in, and take the left side panel off the pc and on the motherboard, you will see either a terminal marked CLRCMOS,JBAT1, CLRRTC, RTC, this is the cmos clearing jumper to revert back to default and the need to reset the time and date. If it's JBAT1 3 pin terminal, the cap will need to be taken off pins 1-2 and put across pins 2-3 then back to pins 1-2. If it is one of the others and only a 2 pin terminal, use a jumper cap like the one on the back of your hard disk and cdrom drive and put it over the 2 pins. start up pc and you should get the screen a beep and it will say press f2 for cmos setup, correct the date and time and the bios should be reset to vga, so change to pci again.
Apr 18, 2007 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
