Question about Opticon LGP-6125 CCD Scanner (RS232 Interface, 2.6 CCD, DB25 Connector with Power Jack, Trigger and Straight... (LGP6125RR1S000) Barcode Scanner
New opticon 6125 RS232 barcode scanner won't read barcodes but old ones will on our factory equipment
2 Suggested Answers
SOURCE: Won't read fonts
dbvfhfh
Posted on Jan 04, 2008
Error - 8 on Opticon PHL 2700
It happened to me once. I basically reboot the opticon. and upload the data to the opticon again. and problem solved.
Apr 16, 2013 | Opticon PHL 2700
Is there a way to check the configuration of a OPTICON OPI 2201?
usually there are no settings as most computers see the barcode and crdit card scanners as keyboard/input devices. unless the manufacture has additional software and drivers the device is simply an input capture device.
Mar 23, 2011 | Opticon Computers & Internet
Windows 7 cannot detecct my OPN-2001
It seems that this only has drivers for Windows XP, but you can try installing the XP drivers on windows 7.
http://old.opticon.com/uploads/Software/USB%20Drivers%20Installer.exe
Here is the link to download the drivers, make sure the scanner is not plugged in until after the drivers are installed. This may not work, but i have had to do this with other hardware and sometimes it does work.
Feb 28, 2011 | Opticon OPN 2001 Mobile Data Collector...
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Opticon OPR-3201-USB computer does not recognize scanner.
get your manual and scan in the appropriate "host" option. You will have to scan in the "USB host" barcode. There may be more than one. Your scanner should be set to the HID usb Keyboard option. Or contact the Opticon Help Desk. You can download the manual at http://office.manualsonline.com/manuals/mfg/opticon/opticon_scanner_product_list.html
Oct 30, 2009 | Opticon LGE1105RHHS-000 Handheld
I just recieved the Unitech MS 183 barcode scanner. The unit when pluged into the computer, will scan one barcode then shut off (The red receptive light no longer appears) and the one barcode scanned will...
The scanner has several modes of operation after reading a barcode. But I comment it may be bad configuration. Check that the mode of connection is correct (usb, keyboard wedge, RS232, etc.). All this programming is done with the user manual, through configuration barcodes. If you do not, then you can download from www.ute.com.
Regards.
Roberto Martinez
Aug 13, 2009 | Unitech MS 183 (MS183)
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
7837 NCR barcode Scanner (RS232)
You can download the pdf from NCR.
http://www.info.ncr.com/Point-Of-Sale/Browse-Search/eRetail-FPS-BrowseBy-ResultsMV.cfm?pl=Retail%20%2D%20Scanners&PID=&title=&release=&cat=&bu=atlanta&sbrn=3&mvc=7837
Apr 30, 2008 | NCR RealScan 7837 Handheld
Symbol LS2208 RS232
Go to the LS2208 quick start manual scan the "Set Defaults" barcode and it will return the handheld to factory default.
Jan 31, 2008 | Symbol LS2208 Handheld
Won't read fonts
Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it (usually by scanning it) to original factory configuration or scan a label that would enable all symbologies.
Aug 03, 2007 | Opticon LGE1105RHHS-000 Handheld
Computers & Internet Logo
Top Opticon Computers & Internet Experts
David Payne
David Payne
Are you an Opticon Computer and Internet Expert? Answer questions, earn points and help others
