Question about Kohler Electrical Supplies
I have a model # 10CC061 Kohler mounted in a Toy Hauler. It cranks and runs about 3-4 minutes and shuts down. It is producing power on both legs, 120 vac. The generator is not running hot,don't run long enough.Could it be low Oil pressure or low Oil pressure shut down???
    Sergeant:
  • 259 Answers
Make sure oil level is up to par. When it shuts down take the wire off the low oil switch and see if it runs.
Posted on Mar 22, 2011
Testimonial: "very good, quick responce"
K300 gas engine. What is output shaft dia and is it keyed?
3/4 Keyed Shaft ' eBay
www.ebay.com/bhp/3-4-keyed-shaft
eBay3/4" Dia. Steel Shaft / Rod 18" Long. ( Keyed 3/16 "both ends ). $34.21 .... 3/4" to 1" inch w/Step Key Gas Engine pulley Crank Shaft Sleeve adapter Predator.
Vertical shaft Kohler Engines - Engine4Less.com
engine4less.com/ALL-Vertical-shaft-Kohler-Engines/
This engine has same mounting and shaft as all KOHLER Single cylinder ... 1"diameter x 3-5/32" length keyed VERTICAL (UP and DOWN ' ) crankshaft. Please ...
Nov 06, 2015 | Kohler Electrical Supplies
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Need 101 help with my WFCO converter//charger Please! I installed a new refrigerator in the toy hauler. Have WFCO 68100 100 amp converter charger with 2-12 volt batteries. The converter seems to...
12 volts to 6 wow not a good thing to do my friend, check your converters power out put bye connecting a load to it,IE headlight or other load if it no light it no workey check for power to the unit AC check for fuses open if not replace the converter, all is OK if you did not get smoke when you connected a fresh set of battery's to your unit toy hauler distribution system.
best regards Falco
Oct 22, 2013 | Wfco WF68100 WF-68100 100 Amp Deckmount...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RES, 12.5kw genset. Less than a
check connections on speedsensor or take down rpms must be a screw or bolt on de fuelpump
Jan 25, 2010 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
Trans slip when pulling toy hauler
Heat is killing your transmission. Change the transmission oil and filter and slow down. Pulling something that heavy is best with a manual transmission.
Jun 15, 2009 | RTO Automatic Transmission And Engine Oil...
Electrical Supplies Logo
458 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
