Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
What kind of oil goes in crankcase - Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
  • Troy Master
  • 8,404 Answers
Rule of thumb for lawn and garden equipment ...
If it is 2 cycle - gas and oil are mixed - 50 to 1 mix. Some two cycle engines require more oil ... up to 32 to one.
It if is 4 cycle - has a fuel tank and a crank case - 30 weight oil SJ or better service rating.
If you want to become an expert on oil ... go here: http://www.bsehome.net/pdf/OIL_S_EG.PDF
And a final word ... it is always good to refer to the manufacturer recommendations when selecting lubricants. Troy Bilt (no longer manufactured by the Troy Bilt Company in Troy New York) uses a number of different engines on their procducts. Here is a link for you: http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54971_54970_54970_-1?cm_mmc=Google-_-WG-_-Tillers-_-Sponsored
Thanks for using FixYa.com
Posted on Mar 22, 2011
What kind of oil do I need to put in the crankcase?
No oil goes into the crank case as it is a 2 stroke. The oil is premixed in the fuel at a 30-1 ratio.
The gear box takes 10w-30 se oil.
May 25, 2015 | 2003 Yamaha YZ 125
Changed engine gaskets and upper intake manifold after antifreeze mixed with the oil and plastic manifold was no good. now I fill te radiator after repair and water goes right to the crankcase and oil pan.
Some where you have lost integrity of the cooling system allowing it to enter the crankcase. If the coolant goes directly into the oil, the problem should be obvious. If you send the year, make and model I may be able to help you locate it. If it overheated, the cylinder head may have cracked.
Apr 17, 2014 | 1999 Buick Regal
What oil goes in the crankcase for a Yamaha YZ 125?
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
what kind of oil can run in my yz125
crankcase oil yz 125 Yamaha 2 Stroke
YAMAHA YZ125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 01, 2013 | Yamaha YZ 125 Motorcycles
Oil backing up through the hole where the old dipstick goes. some kind of pressure problem
all engines burn oil, ALL!
and if you dive faster, it burns more. (rate)
you did not state the rate, here in USA we do
quarts per mile (liters are same )
1 qt/ 3000 miles is norm.
but if you dont service a vehicle , for sure every 60miles.
100km. the PCV valve will clog and the crankcase will go over
pressure, and the car will leak and burn more oil.
the dip stick hole must **** not blow.
if it dont **** , running, the PCV is DEAD !
(1960 to present same deal)
Jan 28, 2013 | 2006 Suzuki Aerio
How much oil and what kind of oil should I use in the crankcase
Here is an owners manual for model 316791961 (7.99 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/1012092L.pdf
Parts listing 316791961
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-316791961/0247/1503820?sid=MMLxMerchandizexManualsModelxx316791961
Oil: (SAE 30 3.04 Oz.)
ADDING OiL TO CRANKCASE: iNiTiAL USE
NOTE: This unit is shipped without oil. In order to avoid damage to the
unit, put oil in the crankcase before attempting to start the unit.
The unit is supplied with one 3.04 fluid oz. (90 ml) bottle of SAE 30 SF, SG,
SH oil (Fig. 6).
Thanks for choosing FixYa,
Kelly
Jul 28, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
What kind of oil goes in the crankcase of the troybuilt pony tiller
here are two websites that will help, the second on is a forum so it may be of more help,Tim:
http://www.ehow.com/how_7983565_use-troybilt-pony-tiller.html
http://forums2.gardenweb.com/forums/load/tools/msg1014281421084.html
Mar 22, 2011 | Mtd Garden
Talon oil feeder wont oil chain 38cc tree hawk
hi
first check the oil filter from the oil tank,the oil hose,remove the oil pump and check it(especially the plastic gear inside,if it worn is because of the bearings from crankcase).Clean the holes where oil goes.
bye savumihai71
Jun 08, 2009 | Garden
Oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
Nov 20, 2008 | 2003 Harley Davidson FLSTFI Fat Boy
Nov 10, 2008 | 2001 Harley Davidson FLHRCI Road King...
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
154 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
