Hi, my HP Pavilion a1620n desktop pc is not displaying .post detect card no IRDY and Frame reset lights ,i cahnge power supply. ram.and unplug all cable ....**** fail. please help me .....plz
    Problem Solver:
  • 15 Answers
1) It might be a motherboard problem, you may have to change a suitable motherboard
2) Try reset your motherboard to default setting,
3) if your motherboard do work, get a old PCI display card if possible. Try to get a display
4) go to HP website to get your latest bios to see everything is in place
Posted on Mar 22, 2011
Yellow light on and pc analyzer sync light irdy frame lights off
Try swapping power supply with a known good unit. The supply may have an issue in the 5 volt section
Apr 27, 2012 | Dell Computers & Internet
No audio device is found on a hp pavilion a1620n computer
you are not installed audio driver so computer is all ways detecting your audio devices so u must install your audio driver.
Sep 06, 2011 | HP Pavilion a1620n (882780664494) PC...
I am having trouble installing a sparkle Nvidia Geforce 8400GS 512mb graphics video card (M/N SFPC84GS512U2LP) on my HP pavilion a1620n. It keeps saying at least one of the display adapters are...
Do you see something like advanced BIOS options? If not then Note down the list of all BIOS menus and options under them , and post them here. Do this and I guarantee that I can resolve your problem.
Nov 10, 2010 | HP Pavilion a1620n (882780664494) PC...
I just inherited an HP Pavilion a1640n desktop from a friend. I don't know if it was working fine for him or not, but when I start it up, all lights come on, fan runs, but there is no response from the...
Please check the power cords which are connected with your computer,and if lose fix it. If your problem is not fixed then remove the cabinet cover and try to fix the heat sink by pressing the A B tabs shown and start the pc.Thanks have a great day222d675.jpg
Jun 09, 2010 | HP Pavilion a1640n (RC663AA) PC Desktop
HP Pavilion 7965 not booting: Just replaced PSU with one that works just fine (got it w/o a power supply) and after checking all connections, powered it on. It turned on and immediately beeped for about a...
You have to have ram memory in, for the computer to operate at a basic function. To get to the BIOS POST screen.
NOTE*
When changing out hardware do you have the power disconnected from the computer?
Yes, I know, but I have to ask.
Also, do you follow anti-static precautions before sticking your hands inside the computer?
Touch the metal frame of the open computer case before reaching inside?
Your body carries Static electricity.
Static can fry out the hardware components inside your computer.
Especially the Processor, which is the most susceptible hardware component to static shock.
1) Computer unplugged from power. Video card removed. Monitor plugged into VGA port on the motherboard. Ram Memory installed. Harddrive data (Interface) cable disconnected, and power cable. Same for any optical drive/s.
Press the Power On button in, and hold it in for a count of Five seconds.
Let go.
Do this procedure 2 more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup back to the factory default settings.
Plug back into power. Wait 1 minute. Turn the computer on.
Do you get the BIOS POST screen? Let's start from here.
Feb 28, 2010 | HP Pavilion 7965 PC Desktop
Hp Pavilion a1620n seems completely dead. Went through a diagnostic and presumed the ps was burnt out. Have since seen the ps light on while all internal cables are unplugged. Can plug all cables in and ps...
No, it indicates a bad power supply.
1) ALL the lights use less than 1 Watt
2) EACH fan uses 2 to 3 Watts
3) A typical processor uses 55 to 125 WATTS.
The base model of the HP Pavilion a1620n Desktop PC, comes with an Intel Pentium D 925
(Operates at a maximum of 3.0GHz)
The Intel Pentium D 925 uses 95 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.28dual_core.2C_65_nm.29
In most cases the inside of the computer is dirty, as well as the inside of the Power Supply, and it's fan.
Heat = Wasted Energy
When the Heatsinks inside a power supply, and it's Fan, (To include the fan blades, fan center hub, and surrounding fan cage), become clogged with gunk, the cooling capacity of the power supply drops tremendously.
Since Heat = Wasted Energy the power supply tries to keep up with the power load demands.
Eventually components inside the power supply fail.
(Usually the Electrolytic Capacitors are the first to go)
The power supply inside a Pavilion a1620n is a common SMPS. Switched Mode Power Supply.
http://en.wikipedia.org/wiki/Switched_mode_power_supply
The style is the common ATX, that is used in over 90 percent of desktop computers. (ATX 12V)
The Wattage is 300 Watts.
Should you like help in finding a replacement power supply that is affordable, and reliable, just state so in an additional comment.
I do advise staying away from the cheap generic models, as they can fail in 6 days to 6 months. ($20 to $25 range)
Jan 18, 2010 | HP Pavilion a1620n (882780664494) PC...
When you power it up the fans start running fast and computer does not do anything else
You should try checking your power supply if it is working properly , check the power cables using Analog Voltmeter, if you dont have any problems with your power supply,then it might be a problem on your motherboard which makes it to act strange, you should try reconnecting the cmos battery to reset the BIOS.
Jan 05, 2010 | HP Pavilion a1620n (882780664494) PC...
Fan running, HDD light solid, no display
I assume there are no post codes (beeps)?
Pull everything including the video card, leave only the RAM and CPU installed.
Try powering it on, You should hear a long beep, then some short ones to tell you the video card wasn't detected.
If you still don't get any post beeps, try resetting the BIOS, and re-seat your RAM.
If it still doesn't post it could be a system board mounting issue, bad system board, bad RAM, bad CPU, or bad Power Supply
Jun 24, 2009 | E-Machines T2240 PC Desktop
Media PC HP 7350n Starts runs for 10 sec or more then powers down
its definately not the motherboard, actually when a ps is about to spoil it starts giving that problem and also, the memory cards are also able to cause this problem too. but first, plz try changing ur ps and see if it works..
Apr 07, 2009 | HP Pavilion a1620n (882780664494) PC...
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
