Hi my miller gas furance burner comes on but the fan does not come on , then the burner goes off soon after ward. any idea's ?
    Scholar:
  • 120 Answers
Sounds like the fan motor maybe bad. take the fan door off and see if you can spin the fan. if not the motor will need to be replaced. if it does turn you will need a volt meter to test the input voltage.jumper the fan door switch and lite off the furnace.with the volt meter on the high speed wire you should see voltage in about 60/90 sec. if you have voltage once again the fan motor is bad. if no voltage your furnace is cycling off on your t-stat or your board is bad.
Posted on Mar 23, 2011
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
Furance starts, runs short time, blower stops short time, then blower comes on, burner still runniing.
Sounds like you fan limit control is not set properly. Or the blower speed is set to high.
Jan 03, 2014 | Intertherm 56000 Btu Gas Furnace
Fan on with gas or with hot exchanger
how do i know it the starter is bad on 2004 gmc envoy
Nov 08, 2013 | Montgomery Ward (223600UP) Heater
I recently came to home to find my furance (natural gas) running but it was blowing cold air. I pulled the filter, it was dirty, cleaned it and replaced it. I turned the furance back on and it worked...
You are resetting it every time you take the panel off the front of the unit. It is locking out the circuit board. No. 1 reason for this is a dirty sensor. The flame sensor is the small rod-like part that senses the flame of the burner. It is usually pretty close to the hot surface ignitor (the part that glows bright when the furnace is igniting) Watch your furnace burner light. You will see the ignitor come on. The sensor is a little bigger than a pencil lead and it will be just a couple inches away from the ignitor.
Take the sensor loose and clean it only with fine sand paper or emery cloth. Chances are this will solve your problem. Hope this helps
Apr 21, 2011 | Heating & Cooling
No heat.. trying to see why.. gas goes on ands ten off in 10 seconds.. the yellow perge light is flashing - maybe related.. help?
Flame sensor at furance nees to be cleaned. Remove front top cover at furance. Flame sensor is located left of last burner .Remove 1/4inch screw and clean wirh fine steel whole.
Feb 03, 2011 | Honeywell Electronic Programmable...
Have a miller furnace. and when i light the pilot, and turn on the furnace. the combustion chamber comes on. it blows out the pilot whats the issue please help no heat.
if the pilot goes out before the fan comes on then your heat exchanger is plugged . if it goes out when the fan comes on then you may have a cracked heat exchanger. it also could be dirty burners with a delay. is there nd slight poping on igintion see if cross overs on the burners are dirty
Nov 25, 2010 | Heating & Cooling
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
Blower inop on auto or manual. burner inop.
Hi check out the fan control afc see if it is clean , check out pressure switch and the flame sencer
Feb 21, 2010 | Coleman Propane Forced Air Heater...
I have a propane furance in a mobile home. When I turn the thermostat up the furance comes on a heats the room to the set tempature. after the room cools back down the thermstat clicks but the burner will...
if you are getting power to the gas valve, then all of the safety switches should be closed. if you have any drain lines off of the inducer fan and at the bottom of the heat exchanger, make sure they have a trap and have water in them. the pressure switch may be the culprit.
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
