Question about Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard
D815EEA2 Bios Update setup mistake other bios but pc running so display can not show..........please Help Me then bios recovery & problem Solution
  • Intel Master
  • 3,606 Answers
Download the bios here at intel:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22D815EEA2%22
Save the BIN file on a usb disk or a diskette
and let the pc boot from it.
Follow the instructons on the screen.
You need to reenter the boot settings in the bios
the clock and the harddrive settings etc.
Hope this will help you.
Posted on Mar 22, 2011
Cant start after BIOS update
It sounds like the boot sector on the hard drive and a bypass of the Bios. Pull the hard drive and try to set the BIOs. See if that works for you.
Feb 26, 2014 | ASUS Eee PC 1215NPU17BK Netbook
Asus motherboard bios recovery
Ekse
Rank:guru_s.gif Guru
Rating: 85%, 1169 votes
In the disk you burned, the bios can't read a zip file, the file needs to be extracted and as far as I remember you need to use a diskette instead of a cd. but I will look into it now.
Comment by Ekse, posted on Aug 07, 2008 Bios warning
Please note, BIOS update is only recommended when experiencing technical difficulties with your system, And is not recommended to be performed regularly.
Moreover, due to the nature of BIOS update, there is certain level of dangers involved. BIOS update must be performed with extreme caution . During BIOS update process, your system must be maintained without interference or power loss to prevent unexpected damage.
In case of BIOS update failure, please follow instructions in your User's Manual for guidelines on BIOS recovery via CrashFree BIOS. In the event that BIOS recovery is not recoverable via CrashFree BIOS, please contact your place of purchase for further assistance on BIOS recovery.
Source Asus
You can get the bios from here
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4V8X-X
Get the 1008 version
its under Bios and 3rd entry, all os version 1008
File is in zip format, needs to be extracted.
the rom file inside needs to be placed in a diskette.
Comment by Ekse, posted on Aug 07, 2008 Diskette or if you can get the bios to read a cd then that is fine also. Comment by Ekse, posted on Aug 07, 2008 if the setup is looking for a file named as
P4V8X-X.rom
it may be required to rename the PV8XX08.rom to P4V8X-X.rom
But im not perfectly sure what you are trying todo or why it is asking for it. il have to look into this more. Comment by Ekse, posted on Aug 07, 2008 As I suspected, BestDarnGood linked us the manual and the correct page about the problem. it confirms that the file has to be renamed and placed in a floppy.
Thanks BDG
http://www.fixya.com/support/p362915-asus_p4v8x_x_motherboard/manual-11149/page-39
Aug 07, 2008 | Computers & Internet
When I try to update Bios on Toshiba Satellite A215-S7462 The computer 'locks up' (becomes completely unresponsive), and the computer's display goes blank (turns off).
Upgrading BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many manufactures have a disclaimer. "You are on you own", and the likes for a reason. Most solutions are found elsewhere. However, if you truly need to update read this to help you with the upgrade. You don't want to end up with a brick. http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Dec 10, 2012 | Computers & Internet
D815EEA2 - No Display But Pc Running Just Try It Bios Update intel.com Site.If You problem Solution ? So Please Help Me................
Try shutdown computer using switch on tower. Restart in "safe mode". Window will pop up and click on "what is system restore", click on that. Another window will pop up, scroll down to "start safe mode", This will take a minute or two. A window will come up and click start or ok. The system will restore back, shut down and restart. Hope this helps.
Mar 22, 2011 | Intel Desktop Board D815EEA2 Universal...
I want to install a new bios for my memory but I don't find the update, my actually version is the v6.0 (7/19/06). It's a phoenix awards bios please help me :'(
Correction the bios update is for the Mainboard or motherboard for a PC. It not for the "memory"? To update your Bios you have to to know the precisely the model/brand of your mainboard before you can download the new bios file needed for the update from the manufacturer site.
There are precautions you need to heed before doing a bios update for the mainboard. In case of any eventualities or mistakes you made may render the mainboard useless!! If you are not 100% sure how to do it, get some professional help.
If you Mainboard is running ie with no errors!, it is advisable not to do the bios update unless recommended by the OEM manufacturer or you need to run a new function from the mainboard which is not included in the old bios.
Hope this helps.
Oct 05, 2010 | Computers & Internet
Can't remember password
BIOS password remove alternatives:
1. Reset Password BIOS via Backdoor BIOS Password.
2. Reset Password BIOS via Software.
3. Reset Password BIOS via hardware.
4. Reset Password BIOS via default manufacturers.
OK, here is my guide to Remove Acer Bios password computer via Software. This has been done on testing machine Laptop Acer Aspire 3620/ Travel Mate 2420. Anyway, I'm not sure it will work on every Acer PC/Laptop so just consider to do at your own risk, I’m not responsible for any damages caused by this guide.
As we know most of Acer computer (Laptop & Desktop) allow us to setup BIOS in Microsoft Windows (9x/XP/Vista) environment. Great, this is the powerful that help us to remove the BIOS password cuz all we know if we enter Setup Utility at the boot time we have only three times of filling the password and if all wrong then the system will halt.
The program helps us to enter Acer BIOS setup in Microsoft Windows is “Acer eSettings Management” which comes with the CD when we buy Acer PC/Laptop. If you lost the CD then just come to Acer website to download the program.
Feb 02, 2010 | Acer Power 1000 PC Desktop
Invalid configuration information- please run setup program & do not enter setup
STEPS
1)"F2" on Dell Logo to go to bios screen
load Bios defaults in bios
Save and exit from bios
2)Install BIOS Update from support.dell.com
Nov 22, 2009 | Dell Inspiron 6400 Notebook
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Leave the connection to graphics card in, and take the left side panel off the pc and on the motherboard, you will see either a terminal marked CLRCMOS,JBAT1, CLRRTC, RTC, this is the cmos clearing jumper to revert back to default and the need to reset the time and date. If it's JBAT1 3 pin terminal, the cap will need to be taken off pins 1-2 and put across pins 2-3 then back to pins 1-2. If it is one of the others and only a 2 pin terminal, use a jumper cap like the one on the back of your hard disk and cdrom drive and put it over the 2 pins. start up pc and you should get the screen a beep and it will say press f2 for cmos setup, correct the date and time and the bios should be reset to vga, so change to pci again.
Apr 18, 2007 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard Logo
119 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
