Question about Fuji Cameras
I have a Fuji Finepix AX245w digital camera. An error message is showing statin 'protected card' so therefore i cannot erase photos or take any photos. How do i clear this please?
  • 262 Answers
Hi, I've checked out your Fuji Finepix AX 245 and it uses standard SD or SDHC cards; this question has come up before, so I'm pasting you a complete answer that I wrote a while ago - hopefully it will allow you to clear the problem in your case!
Why does my camera say "Card Locked" or "Write Protected"?
The basics. In the same way that the recordings on audio cassettes and VHS tapes could be protected by breaking off the little tab on the back corner, the material on a memory card can be protected against being overwritten. Instead of a tab to break off, write protection is done by a tiny slider on the edge of the card (opposite the cut corner). Before the camera will take pictures, it's necessary that this slider on the card operates a microswitch in the camera, which it will only do if it's NOT in the 'lock' position. The slider actually does nothing inside the card, which is why I don't call it a 'switch' even though it seems like one. Its only purpose is to be detected by the microswitch in the camera's slot, and it's the camera that takes care of the write protection, not the card.
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
If only one memory card exhibits the problem: In this case, it's clearly something to do with the memory card. Is the slider worn, bent or missing? A missing slider will write protect the card in the same way that sliding it to the 'lock' position will. There's another possibility. I've recently discovered that
some cameras which use xD-Picture cards also give this error even though those cards don't even have lock sliders! Furthermore, some users have reported fixing this error by reformatting the card. Therefore, I feel it's also possible that your error may be fixed by reformatting. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If some memory cards work, and others don't, or the same cards sometimes work but only sometimes:
The slider is really tiny, so it's possible that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Does a better brand of card work? Can you bear to simply stick to the better brands, or the ones that work most reliably? As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I think this is a risky solution. There's a risk that the tape will come off in the slot and cause even more problems, or that the tape will be so thick that the card will jam in the slot and you'll have trouble getting it out.
If all of your memory cards behave in the same way: In this case, it's clearly something to do with the camera. It could be that the microswitch is broken, or there's some software error. Although it's less likely, let's cover the software error first; please find the 'system reset' function in your settings menu and use it to clear everything. Any good? If not, try the sticky tape solution in the last paragraph in the hope that it's a size/fit problem with operating the microswitch, but if that fails we're out of options really, beyond a repair of that microswitch.
Posted on Mar 22, 2011
Fuji AX245W given to me as a gift. it only appears to take and store 5 pictures. Is this because I need to buy a separate memory stick
Yes it is. It's only using the internal menory now.
You need to buy a SD card, "memory stick" is different type of card.
Sep 28, 2010 | Fuji FinePix S700 Digital Camera
MESSAGE SHOWING CARD NOT INTIALIZED
Initialize means to format the card....this will completely erase it.
Jul 14, 2010 | Fuji FinePix A205 Digital Camera
I have a Fiji Finepix Z20fd camera, and have approx 350 photos on the memory. Yesterday the message "memory full" appeared when i tried to take a photo so naturally i attempted to delete a some to make...
Having pics on both the internal memory and a memory card is asking for trouble. Take out the card and download the internal memory to your computer. Then, go into the menu and find "format" and erase the internal memory. Then, download all the pics from the memory card using a separate card reader. Then, insert the card into the camera and do the format thing again to erase and optimize the card. Now you have a fresh start...never use the internal memory again.
May 03, 2010 | Fuji Finepix Z20fd Digital Camera
Finepix ax245w how do i shoot in black and white setting
read error keeps coming up when i try and look at pictures i have already taken
Apr 23, 2010 | Fuji FinePix S5000 Digital Camera
My fujifilm finepix s1500 tells me there's a read error when i want to look at photos i have taken, they don't show up when i put my sd card in the computer either, how can i fix this?
i have the exact same problem it works again when you erase the memory card i think its nont the actual memory card but a general camera problem ive tried both my sd 8 gb card and sdhc 16 gb card and both have the same problem
Feb 02, 2010 | Fuji FinePix S1000FD Digital Camera
Error read - message given when I try scroll through pictures taken. Can only see the first picture then the "error read" appears
I had this problem! just solved it by erasing all the photos off the card (or reformat it) hopes this helps!
Oct 16, 2009 | Fuji FinePix E900 Zoom Digital Camera
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
Protected card on my camera
Check your owners manual about protected photos. There is a setting in the camera's setup that keeps you from accidentally erasing photos.
Apr 30, 2009 | Fuji FinePix S1000FD Digital Camera
SD card Protected
It sounds like the tiny locking switch on the SD card has accidently been set to "lock". Remove the card from the camera and slide the switch to the opposite position. That should do it.
Apr 25, 2009 | Fuji FinePix Z10fd Digital Camera
Fuji FinePix 3800 Initialization glitch
Turn camera from "off" to "play" ( photo view..._
Pressing the “MENU/OK” button as you would to erases files. There is an option to format the xD-Picture Card. Formatting erases protected files, but allows you to then take photos.
Nov 15, 2007 | Fuji FinePix S7000 Digital Camera
Cameras Logo
380 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
