Hard Disk Problem
Hi again,
Hoping for a help form someone that can help me with my problem here.
My hard disk could not be detect in windows.
1. The hard disk is detected and appear in BIOS
2. In windows, the hard disk dissappear. When clicking at safely remove (system tray) hardware, the device is there and can be stopped
3. Already check at disk management, the drive did not appear
4. Already try with other computer, the same problems occurs and still cannot be detected.
Hope someone can help me with this problem as my data still in the hard disk
  • Kamal Aug 03, 2008
    Thank you for the help, i tried the tools, seems that still cannot find the drive. For addition, the drive is external hard disk with USB extension and with 40GB Quantum IDE drives
Hi I have aproblem of hd. I lost 10 HDD the most of them are from seagat Maxtor and western digital; What is wrong with these manufactrors?
The problem hapen after formating, re install win xp. often I get the message Operating system not found. NDTRL ....something like that
May the problem is the bus, or the sloteK?
or may the cause is jumper positions?
or simply that HDD is dead, and it the case how to fix it?
Please need a help, thank you
addoud
Posted on Nov 22, 2008
    Problem Solver:
  • 13 Answers
first download and install Drive Rescue . Click on Find lost drive, select the drive you miss and click "find logical drives". Now you should access all of your files. Save them to another drive and format the hard disk.
hope to be helpful
Riccardo
Posted on Aug 03, 2008
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
Hello my laptop wont open,it brings numbers that ask me to insert a boot disc,i dont have any ,what shall i do to start to start my windows.
Hi "Wambuilyds"
It show no hard disk is detected in your laptop, please check your BIOS to know the Hard disk is detected, also try to re connect your hard disk.. if the problem exists buy new Hard disk and install windows again,, Thank you
Aug 27, 2011 | Toshiba Satellite Pro L300 Notebook
Bios cannot detect hard drive suddenly. I was running the PC well. Trying to start the PC again, cannot go into windows. Check on the bios, no hard drive detect.
Follow the steps given below.
1) First, check your hard disk cable, I recommend you to replace the Hard Disk Cable.
2) If the BIOS doesn't detect your Hard Disk after replacing Hard Disk cable try upgrading your BIOS from the Dell website.
Jul 06, 2011 | Dell Studio Xps 9100 Desktop Computer
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
Hi, when I power up my laptop, it get a message saying boot from a bootable device, if I click on any function key when the logo appers the system will boot into windows
It appears your hard disk has failed. Go to the BIOS configuration and check if the BIOS detects the hard disk, if not then re-seat the hard drive and then check the BIOS again.
If the BIOS still cannot detect the hard disk then it is faulty.
To get your computer working again, replace the hard disk, install Windows on the new hard disk plus the motherboard's device drivers and your programs.
Jan 24, 2011 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
My laptop does not boot. it always ask for a cd to boot but i already reformat it.someone told me that it is a hard disk problem and advice me to replace my hard drive.
When the computer starts it flashes up press f2or delete or some other key to enter setup. Go through the settings and there should be one that will allow you to change the boot device. It sounds to me like it is set to boot from the cd rom drive only. Change it to boot from the hard drive and save changes to CMOS and restart the computer. The computer should now boot from the hard drive.
Aug 01, 2010 | Compaq Computers & Internet
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
It doesnt detect my harddrive and it causes windows to crash...how do i fix it?
If the BIOS cannot detect the hard disk then probably the hard disk is faulty.
To check if the hard disk is faulty, remove the hard disk and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot detect the hard drive or open the folders and files, then the hard disk is faulty.
To get your computer operating again, replace the hard drive with a new one and install Windows on the new hard drive plus the computer's device drivers and your programs.
Mar 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
I cannot get my gateway gt5028 to reboot,, i have no disc,, people tell me yiu can reboot and get computer back to normal without one,, help!!
there are 2 things about reboot that is the reboot from the bios or reboot from the windows... if you mean you can't reboot and there are no hard disk as your primary hard disk try to check if the bios detected the hard disk. by pressing Delete key when you start to reboot the computer... make sure there are someone with you who knows something about the computer BIOS. if not keep in touch.. in Main menu in BIOS you will find If the computer detected the hard disk, if not detected try to check the IDE/SATA cable or Power Cable of your hard disk. Check if that hard disk is the first boot in the Boot section of the BIOS, if not then change the Hard Disk as your first boot.. That will help you boot your computer properly in windows..
Dec 05, 2008 | Gateway GT5028 PC Desktop
Computers & Internet Logo
437 people viewed this question
David Payne
David Payne
