Question about D-Link DIR-615 Wireless Router
Hello,, I got a DIR 300 Dlink router and I have a 1MB Internet service, my problem is because I am trying to install an IP Camera on my office but the upload is extremly slow when routers come into the network. The fact is that i need the router in order to get at least two cams and my usual web service. My download is average 1.75 MB but my upload is just 0.1 MB with the router (without the router average 1 MB) I really need to solve this..! please any help will be granted.
  • D-Link Master
  • 7,733 Answers
Call your ISP provider an ask the same quest here.
Posted on Mar 22, 2011
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
Hi, i have a dlink dir-412 mobile router. how can i add an ip camera in this router. i will connect to internet via modem. i get an dynamic ip address after conect to internet. is it possible see the ipcam...
access your router using 192.168.1.1 username/passwd if not altered should be admin/admin u can set your ip (static ip) and i do not see why you can not assign an ip for your cam, my guess is you want to veiw you the camera feedback across the Internet. there various ways of doing this just remember that your cam is connected to your local network not to the Internet. good luck
May 09, 2011 | D-Link 3G Mobile DIR-451 Router
My dlink dir 300 was working fine with our 2 laptops. i bought a blackberry phone and tried to set up wifi connections. blackberry phone asked me to enter some nos. for the router. so i did. then our...
1. Restart the router by plugging it off and back on
Try to connect again
If that does not work,
go to the router's configuration page
Make sure you have DHCP enabled to assign ip addresses
Also on the devices, check to have Wi-fi turned on, and iP address to be configured automatically.
Please check and provide feedback
Regards,
Katharsys
Mar 07, 2011 | D-Link DIR-300 Wireless Router
Hi. I just configured a DLink DIR-300 wireless router on my laptop. During the installation, it required me to keep the ethernet cable connected between the router & the laptop. I finished the...
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Aug 19, 2009 | D-Link DIR-300 Wireless Router
Need software for dlink dir 301 wireless router
Here is the link to the manual for your router. Follow it's instrunctions to login into the router and from there you can run the setup wizard. If you feel comfortable in doing so, you can set the wireless configuration manually. Please reply if you need specific assistance.
http://74.125.93.104/search?q=cache:FT1VlyIdfuUJ:ftp://ftp.dlink.co.uk/dir_products/dir-301/DIR-301_Manual_English.pdf+dlink+dir+301&cd=5&hl=en&ct=clnk&gl=us
Good luck and thanks for using FixYa!
Apr 09, 2009 | Computers & Internet
How to put security protection (wep) on dlink dir-300?
go into your local ip modem ip and login with admin and paasword. then look up every tab until you will find the wep key tab ;D
most common ip's is:
192.168.1.1
192.168.0.1
192.168.99.1
Feb 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
D-link DIR-635 router
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link DIR-615 Wireless Router Logo
272 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
