Question about AEG 23 in. F44080I-A Aluminum Built-in Dishwasher
HAVE AEG F406601M PNC91123471900 . WILL NOT DO ANYTHING. HAS 4 LIGHTS ON R H SIDE OF CONTROL PANEL,THE TOP 2 LIGHTS OF THE 4 FLASH WHEN MACHINE ON ALONG WITH THE LIGHT THAT INDICATES PROG SELECTED.
5 Suggested Answers
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
  • 417 Answers
SOURCE: aeg santo 1688 fridge power/light flashes when door open
Check if the bulb is loose in its socket, you may be able to twist it to tighten it, turn off the power first though.
Posted on Oct 13, 2008
SOURCE: The top oven of our AEG D5701-4 is slow to heat.
The AEG Competence D4100-1 oven is a load of expensive rubbish.I am going to throw mine out and get a good cheap oven of a different make.Stay away from AEG as their products are very poor quality.We have had nothing but trouble with our oven and our hob. Also no help from AEG customer services.
Posted on Feb 17, 2012
adrianaloret
SOURCE: AEG Lavamat Turbo 12710 update. Machine is
hello i have the same problem has the person above said but cant find the brushes on the motor, what can i do ? NEED HELP PLEASE
Posted on Jan 23, 2013
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
How to get into the control panel on a Kenmore Elite H E 4 Gas dryer
You'll have to first take the top off the machine by removing the three screws at the top rear of the machine. Once they are out youcan then slide the top back and you'll have access to the control board from the rear side of it. To actually remove it there are two screws, one on each side that you'll have to take off then the whole display can be removed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Aug 25, 2012 | Kenmore Dryers
AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts to flash. Door indicator light then goes from...
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
Jan 07, 2011 | AEG Lavamat 12710 Front Load Washer /...
FDW 60 lights 4 and 5 flashin.Select programme,m/c then bleeps 4 times and then lights 4 and 5 flas together and nothing else happens!Any ideas please?
Control panel which is a bit sensitive might need re-booting. Mine did the same and had a mind of its own, doing what it wanted, lights flashing all over the place, not completing the wash etc etc.
Switch off the machine and unplug from the mains. Leave for 10 minutes.
Plug back in, switch the machine on to your required programme and if ,like me, you are lucky, your machine should work again. If it happens again in the future you know what to do. Failing that go to the Hotpoint website, find the customer service number and ask if there is anything else you can do yourself to solve the problem, before paying for a service call. They are really helpful
May 27, 2009 | Hotpoint 24 in. FDW60 Free-standing...
AEG 3032 Oven, no light, no main fan, no heat to grill or oven however the exhaust fan does operate when the grill/oven is switched on. The thermostat clicks when moved from 0 to a higher temperature but...
If you are sure the timer is set to manual and not auto , then I would say that it sounds like the selector switch is faulty or the thermostat is faulty, some times they are combined as one unit, and sometimes they are 2 separate switches.
You need to remove top cover of oven and have a look inside the control panel and see if there is anything obvious like a burnt wire or bad connection
If it is a combined unit, then sometimes the 2 parts of the unit become disengaged or the cam inside the switch breaks.
Plz rate my solution .
Thanks.
Jan 05, 2009 | AEG B1180-4 Electric Single Oven
Aeg santo 1688 fridge power/light flashes when door open
Oct 13, 2008 | AEG Refrigerators
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
AEG 23 in. F44080I-A Aluminum Built-in Dishwasher Logo
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
