Question about HP OfficeJet 6110 All-In-One InkJet Printer
Align cartridges - HP OfficeJet 6110 All-In-One InkJet Printer
Why don't you just show the manual. I must have misplace mine. I have replaced the cartridge and want to check the alignment. I have an alignment page printed, but what do I do next.
Posted on Oct 31, 2008
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
How do i align my printhead on canon iP1200
I assume you are using windows.
  1. Go to START, SETTINGS, PRINTERS, double click on the printer icon. Go to FILE, to PROPERTIES, then click on the printer SERVICES tab. Click on ALIGN the print cartridge button and follow instructions on the screen. hope this works
  2. Align the print cartridges Typically, you only align print cartridges after installing or replacing a cartridge. However, you may also need to align cartridges when:
    • Characters are improperly formed or are misaligned at the left margin.
    • Vertical, straight lines are wavy.
    From your printer:
    1. Load plain paper.
    2. Press the Menu button, and scroll to Align Cartridges.
    3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
    From your computer:
    2. Open the Canon Pixma IP 1200 Utility.
    3. From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears. alignprintcartridgesa.jpg alignmentpanther.jpg
    4. Click Continue to print the alignment page.
    5. On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
Apr 20, 2011 | Canon PIXMA iP1200 Photo Printer
I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
  1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
  3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
  4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
  1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
  2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
  3. Click the Device Services tab.
  4. Click Align the Print Cartridges .
  5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
  7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
  8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Apr 19, 2011 | HP Office Equipment & Supplies
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
Feb 16, 2011 | HP OfficeJet 7410 All-In-One InkJet...
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
I have a hpdeskjet f2180 and need to change the ink cartridges. How do I get to the cartridges to change them !
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely when you try to remove them.
  2. Open the print cartridge door. Figure 1: Opening the print cartridge door c00906461.jpg Make sure the print carriage moves to the center. If it does not move to the center, turn the device off and then turn it back on again.
  3. Remove the tape from both cartridges. Figure 2: Removing the tape from a cartridge c00651128.gif CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 3: Copper-colored contacts c00651129.gif
  5. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Figure 4: Carriage slots c00853116.jpg Figure 5: Inserting the tri-color cartridge in the left slot c00853117.jpg
  6. Make sure you push the cartridges in firmly until they snap into place. Figure 6: Pushing the cartridge in firmly c00853118.jpg Figure 7: Tri-color cartridge and black cartridge correctly installed c00853119.jpg
  7. Close the print cartridge door. Figure 8: Closing the print cartridge door c00906462.jpg
Aligning print cartridges The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print cartridges ensures high-quality output. NOTE: If you remove and reinstall the same print cartridge, the HP All-in-One will not prompt you to align the print cartridges. The HP All-in-One remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. To align newly installed print cartridges
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. Figure 9: Loading the alignment sheet c00906464.jpg
  3. Press the Scan (c00906465.jpg ) button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Jul 29, 2008 | HP Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
259 people viewed this question
Ben Johnson
