Question about Craftsman 10" Table Saw
The motor spins but the blade does not; the blade is not loose
    Sergeant:
  • 259 Answers
It sounds like your belt from the motor to the saw is too loose has to be tightened.
Posted on Mar 22, 2011
  • jdzoino Mar 22, 2011
    there is no belt; thanks though
  • gcorner868 Apr 15, 2011
    when i have the belt off, the motor turns fine, when i put the belt on blade wont turn. the belt tightens by the weight of the motor.
Cuisinart mini-processor, motor runs but blades get stuck and motor just spins? I tried replacing blade, no help
The set screw on the blade assembly is loose. If the motor does not spin then that is a different story.
Nov 24, 2016 | Cuisinart Food Processors
My Ryobi 10" chop saw was stopping mid-cut. Why is it making an awful noise now?
The nut that holds the blade on May gave come loose. Or motor is shot
May 02, 2015 | Saws
My silver bullet helicopter wont take off, the top blade is spinning but the bottom one isnt
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
Jan 01, 2014 | Shuttle 9094 Emax Remote Control...
Ceiling fan off track
Might have broken the flywheel if this fan has one. The flywheel is the is the round rubber wheel that the blades attach to. If I knew the model of the fan I would know if it has a flywheel.
Aug 31, 2013 | Casablanca Fan Dryers
My 1993 ford taurus's wipers work part of the time. You can hear the relay click. but when they do work, the motor is fine. delay works and all.
Check if the wiper fuse is loose in the fuse box. Take it out and reinsert it. If it is still loose, take a small short piece of wire and insert it with the fuse to make in tight in its fuse slot.
Aug 18, 2010 | 1993 Ford Taurus
Turn saw on, Curcuit pops immediatly
The motor is bad. It is drawing too many amps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jan 28, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
Motor works but blade not spinning
Check and make sure that the shaft in the base housing spins. If it does, the blade assembly has become disconnected from it's shaft probably due to an improper spot weld or peening of the blades to the shaft, or has torn loose or ripped the splines out due to an immovable object trying to be spun. A jammed ice cube can do this. Blade assemblies can be had usually directly through the manufacturer and usually on line. If this has helped, please rate it accordingly.
Jul 20, 2009 | Westinghouse 0101 IntelliBLEND¿ Work...
Can you tell me what is causing my delta mitre saw motor to run but the blade does not spin powerful enough to cut moulding?
Maybe the bolt which holds the blade on is loose. If the motor is on the RIGHT side of the blade, then the bolt has 'left-hand' thread. Turn it counter-clockwise to tighten.
Jun 19, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Skil saw motor runs but blade won't spin
you have a loose nut.  Let me explain...the nut and washer that holds the blade to the motor has worked loose.  You need to remove the plate around the blade to acess it and on the end of the blade is a large nut.  Tighten it with the power off.  Sometime there is a grove on the motor shaft to hold the motor or sometimes you need to put a screwdriver into the teeth of the blade to hold in place to tighten.
Apr 04, 2009 | Skil 10" Table Saw
Maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Sep 22, 2008 | Freezers
Craftsman 10" Table Saw Logo
91 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Tim Venetis
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
