Question about Electrolux Kitchen Ranges
We have a Chef GSC6638S Chef Upright 600MM - just out of warranty!! Oven will not light - even when timer is switched to manual mode. Gas supply checked and fine. Power supply checked and fine. Cook top working on gas supply with electrical start working fine. Oven fan and light working fine? Any clues to what the problem may be?
    Scholar:
  • 93 Answers
Check the oven ignitor may be its weak ,unable to draw enough ampege to glow. or your safety valve is shorted.
Posted on Aug 03, 2008
I need a manual for gas appliance Chef Select GUC5115WNG. Could anybody please help me out? Thanks & Regards
'chef guc5115wng upright kenmore gas oven manual
can be found at :searspartsdirect.com
Dec 03, 2013 | Kitchen Ranges
Oven will not light
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 16, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven timer making whirring notice even when it's not in use. Chef Electric upright stove
Those generally don't come apart and all you can really do is replace the timer if it is still available.
Aug 06, 2009 | Kitchen Ranges
Cpr1100adw magic chef
Most, if not all, gas ovens do not have pilot lights any longer. They are electronically ignited. You could have a loose wire on the igniter or a faulty igniter. If your oven is new it should be covered by the warranty.
Jul 26, 2009 | Magic Chef CPR1100AD Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Jul 29, 2007 | Magic Chef CGR1110 Gas Kitchen Range
Kitchen Ranges Logo
280 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
