Question about Jenn-Air JED8230 Electric Cooktop
Replacing jennair cooktop with slide in range
I currently have a downdraft jennair cooktop in an island and would like to replace it with a slide in range to gain some countertop and cabinet space. Besides having to rewire (currently 40 amp/ need 50 amp for range), will I also have to move the position of the range in the island? The current cooktop sits slightly back of center from the venting hole in the floor. Looking at the installation instructions for the downdraft range, the hole should be placed in the back right corner under the placement of the range. The difficulty is that the house is built on a slab. The other problem is that there isn't enough room in the kitchen to position the range anywhere else without leaving too little space between the island and the opposite cabinets. Is anyone out there familiar with installing this range?
I've spoken with a couple of contractors who've come out and looked at my cooktop and the venting and looked at the install manual for the jennair range and they don't seem to know whether I'll be needing to break the slab to install the range (not being familiar with putting in downdraft ranges I guess). I want to do some updating in the kitchen with new cabinets and countertops but I want to know whether it's possible to change the cooktop to a downdraft range first and how involved it's going to be. Thanks for any help you can give me on this.
3 Suggested Answers
SOURCE: downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Posted on Nov 30, 2008
jyackle5
  • 8197 Answers
SOURCE: I need to remove my Whirlpool Gold ceramic cooktop.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
Posted on Dec 16, 2008
aasc
  • 1606 Answers
SOURCE: Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Posted on Aug 08, 2009
Problem w/ plastic knobs on JennAir electric downdraft cooktop
NO METAL KNOB FOR THAT MODEL COZ IF USE METAL EVERY TIME U USE IS HOT THATS WHY DESIGN FOR PLASTIC,MUCH BETTER TO U REMOVE THE KNOBS AFTER U TUNN ON THE HOBS TO LESS MELT THEN RETURN IT IF U TUNR IT OR ADJUST.
May 17, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Downdraft cover and grill grates
i bought mine new from HD. Neither the dd cover nor grill grates have bushings on them. however thats a good idea.
Dec 31, 2008 | Jenn-Air JGD8345 Gas Cooktop
I have a KitchenAid KESS907SSS 30" Slide-In Electric Range with a broken glass cooktop. I have the replacement cooktop and want to do the replacement myself as I live on a remote island. It looks like...
Problem solved. Followed the instructions given and successfully changed the cooktop.
It turned out that the front control panel needed removal in order to access the screws behind it. After that it was clear sailing.
Thanks for your help with this.
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft vent on jenn air cooktop
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
JED8430 Fan Burning
great love it when people do this just commom sense most of the time
Dec 28, 2007 | Jenn-Air JED8430 Electric Cooktop
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Installation of new electric cooktop
If you're talking about a downdraft style cooktop, you will just need to measure the discharge vent diameter and shape and match that up. Not all are the same shape but most are 6" diameter
Apr 22, 2007 | Whirlpool 30 in. RC8700 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
482 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
