Question about Texas Instruments Office Equipment & Supplies
I have a TI-35II which will turn on and the screen shows 0 and DEG, but I cannot get anything else to happen. It can also be turned off. It would seem that it has fallen on the floor one too many times and the keyboard has lost contact. I would try to open the case, but I don't like to use too much force. It was purchased in UK. The serial number is RCI 5084 Thanks for any help.
  • marcus324 Mar 25, 2011
    Thanks for the reply, but there was another part which was not answered: I asked how the case was opened.
    Guru:
  • 1,833 Answers
As you mentioned, that it has fallen on the floor many times, the internal circuits may be damaged, connection with key board can also be interrupted. It needs to be repaired.
You can visit these web sites for more help and support http://www.contacthelp.com/directory/Texas+Instruments?ListingID=49,
"www.calculatorsdirect.co.uk".
Posted on Mar 25, 2011
  • 6,771 Answers
From your description the main contact board is more than likely cracked and will probably need to be replaced, or one of the plug-ins has come loose. I suggest someone who is handy and is comfortable taking it apart, these units can be tricky to work on because they are so compact and it needs someone with good skills.
Posted on Mar 22, 2011
How do I reset my TI-86 after a long period of no use.
Every time you change batteries this will happen to you. First press 2nd then press and hold the down arrow. Hold until their is no black in the background but you can still see the numbers on the screen.
Sep 05, 2014 | Texas Instruments TI-86 Calculator
DEG on screen
On the 30Xa, press the DRG key to cycle through the different angular modes. Be aware that no matter what mode you set, the display will show an indicator of the current mode. You can't remove the indicator completely.
Dec 11, 2013 | Texas Instruments TI-30XA Calculator
When i turn my calculator on it shows deg, rad, or grad. how do i get this off of their?
You do not want any of the three displayed? Well, YOU CANNOT. One of the indicators has to be displayed, to remind you the user that the angle unit is set to degree, radian, or gradian. By Texas Intelligent design.
I know, it is your calculator and you may want it to behave as you will it, but that part of the screen is OFF limits to you. You cannot enter anything directly in it. If you make configuration changes, they are reflected in that inaccessible part of the display. Now, do you still want to get rid of all three?
Sep 19, 2011 | Texas Instruments TI-30XA Calculator
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
How do I reset the calculator after installing new
[OFF] ON/C] clears display, errors, all pending operations, constant calculations K, and STAT, but not M1, M2,and M3. Sets DEG angle units, floating-decimal format.
To clear memory M1 : Store 0 in 1
0 [STO] 1 clears M1
0[STO] 2 clears m2
0 [STO] 3 clears M2
Feb 03, 2010 | Texas Instruments TI-30XA Calculator
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
Press [2nd][+] (") to access the double quotation mark
Press [ENTER]
Jan 06, 2010 | Texas Instruments TI-85 Calculator
TI-30Xa doesn't react to any button. It is on and reading 0
hi..
First, you want to make sure the calculator is in degree mode. Hit the "DRG" button until you see "DEG" in the display.
Then do the following keystrokes:
8 x 28 [sin] = ÷ 21 [sin] =
That should get you 10.48021316 in the display.
Get a new instruction booklet by download from TI website.
Hope this helps. Thankyou
May 05, 2009 | Texas Instruments TI-30XA Calculator
Put new piston rings in but dont know the timming marks for it does anyone know
Here is the manual which should give you all you need regarding your bike so rate me if it helps you thanks....
http://www.husqvarnaracingclub.cz/images/home/ohqv/manualy/2003/Workshop/2003%20TE610E-SM610S.pdf
TDC spark 0 deg
exhaust opens: 91deg [89 deg before BDC]
BDC 180 deg [1/2 turn]
intake opens: 310 deg [50 deg before TDC]
TDC lost spark: 360 deg [1 turn]
exhaust closes: 400 deg [40 deg after TDC]
BDC 540 deg [1 1/2 turns]
intake closes: 617 deg [77 deg before TDC]
TDC spark 720 deg = 0 deg [2 turns]
here are some important couple of links...
http://www.advrider.com/forums/showthread.php?t=141762&highlight=Husky+Husqvarna
more on proper nut and bolt securing.....
http://www.advrider.com/forums/showthread.php?t=156429&page=244
Apr 02, 2009 | 2000 Husqvarna TE 610
27 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
