Question about Thetford Refrigerators
When we switch on fridge it is kicking out the breaker on the fuse box
    Problem Solver:
  • 53 Answers
Check the cable near compressor area may be short / compressor serious starting problem
Posted on Mar 22, 2011
Where is the fuse box on my 01 forest river salem 26 foot pull behind camper
I've had RV's with fuse/breaker boxes just inside the entry door and my motor home has vehicle fuses under tip up dash, RV fuses (breakers) near floor under fridge.
May 27, 2017 | RVs
Where is the fuse for the power seats located?
PWR ACCY Fuse Breaker A
25A Located in the instrument panel fuse box.
I/P Fuse Box In the left lower kick panel
Power Seat(s), Illuminated Entry Module, Power Door Lock Switches, Remote Control Door Lock Receiver, Power Door Lock Control Module.
Do you have a problem with any of the other components listed ,if no the breaker is good .
Do you have
Jan 31, 2016 | 1999 Chevrolet Express
Fuse panel in k z 204s
The fuse panel is located in the breaker box to the right of the breakers. Each fuse should be properly labeled. If a fuse is blown and there is a draw on that circuit there should be a red led that will light up to indicate which fuse has failed. If you have any other questions please respond to this thread.
Jun 22, 2014 | Palomino 2013 Puma 31-DBTS
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
My CPle30-1 wont kick on, where do I start with the problem solving. where would the fuses be?
you start at your breaker box making sure the breaker isnt tripped then you move to your disconnects checking your fuse's or breaker it may take nigther if this is a split system check the drain pan make sure theirs no water in it it will kick the float switch out after all this is good check your filter,coils finally after these things are good check your capacitor it a canister with wires pluging in to it its very common for these to go out please rate my help and give me a vote if you need further help email at pendletonheatandair@hotmail.com
Sep 19, 2010 | Goodman CKL42AR42 Air Conditioner
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Runs constantly. Coils extremely hot. Breaker kicks out infusebox
It sounds as if the compressor is overheating causing a large current draw throwing your breaker. If the coils are durty on the back....clean them..also clean the coils under the frig by the fan motor.
Aug 21, 2009 | Refrigerators
Sub zero 700tc/fan runs but no compressor
A check of your breaker is in order. From your description the breaker could be week. If so the breaker my not cut off all the way and still allow enough power through to opperate the fan but not the added load of the compressor.
I have seen this a few times and it always confuses me too. Check the circuit by maybe moving the circuit on the breaker to a different one then retry it and see if the problem is gone. If it is then replace the breaker if not then its time to use a volt meter or call a repair person. And this is because there are a lot of what ifs that have to be covered to get to the root of the problem if this is not the trouble..
Please lket me know whow this works out. Rate me as high as you can and thank you for using fixya.
Apr 28, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Refrigerators Logo
105 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
