Question about True T-49 Side by Side Refrigerator Commercial
Left door doesn`t close by itself - True T-49 Side by Side Refrigerator Commercial
    Problem Solver:
  • 53 Answers
Check the beading correct may be twisted / Bottom foundation screw adjust / Check bottom door hinges plastic sleeves damaged.
Posted on Mar 22, 2011
Left hand door not closing easily anymore. lubricate the hinge?
It could be the fridge is tilting forward.
Up turn the two front screw beside the door to make the fridge tilt backwards, or lower down the two back screw to allow the fridge to tilt backwards.
Then the door will automatically close by the weight of the door itself!
Jan 24, 2015 | KitchenAid Refrigerators
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
Aug 18, 2012 | 1994 Volkswagen Golf
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
Error Message: Fuser door open
You have to look on the sides of the printer where the door closes. Here it should be a mechanical sensor. Make sure that it closes properly to sense the door is closed. If it doesn't, it needs to be replaced. More exactly, it's a sensor underneath the fuser door activated by a plastic arm, which is difficult to see. This sensor has a spring arm against which the plastic arm pushes and you have to bent the spring arm out just for a second so that the sensor can activate by itself.
I hope I helped you!
May 19, 2011 | Office Equipment & Supplies
Whirlpool side by side refrigerator door not closing by itself. Ideas?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Right door will not stay closed
Put vaseline on door seals
May 26, 2009 | Maytag MSD2758GEW
Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
True T-49 Side by Side Refrigerator Commercial Logo
171 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
