Question about VIA Garden
I have a 196-036 timer. Stored it inside during the winter. Hooked it up yesterday, everything works, (info panel), but it will not allow water to disribute. Tried manual and auto programing. Any ideas?
  • 56 Answers
Most issues of this sort with these timers is water pressure holding the valve shut. Reduce the flow from the spigot and try again. If the timer still does not operate properly I would suggest removing the timer from your water system and manually activate the valve. Listen for the solenoid to click open, this can be fairly faint so it may take a few tries to definitely tell if it is operating. If the solenoid will not operate it would be best to replace the unit.
Posted on Mar 22, 2011
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
After winter storage and frost interference my gardena water control T1030 plus seems to misbehave. There is a small hole on the side of the filter (which I haven't noticed before) through which a strong...
If you leave water inside plastic timer or plastic hose parts, and water freezes during winter, then the plastic will split as frozen water expands.
Buy new water control.
Open link below for some Gardena manuals including T1030
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
By the way, if they made the same parts out of brass or copper, the brass and copper would expand instead of crack during a freeze, but the internal valves would be ruined anyway.
So plastic is a good material, just bring these things indoors or drain the water for winter storage.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 31, 2011 | GARDENA Water Timer #31169-4
Hooked it up with water started engine and no
Your water system is plugged with "gunk"
You will need to slush it out with water and air pressure if you can until it runs clear
Apr 04, 2010 | Briggs Stratton 020273 Elite Series...
Should i remove the battery from my 1999 vt750 ace when storing for the winter
I would suggest it's more a matter of whether the bike will be stored inside or outside. the battery can freeze if it becomes discharged during the winter. as long as you intend to keep the battery charged occasionally during the winter it can stay where it is, if not take it out and store it inside.
Nov 30, 2009 | 1999 Honda VT 750 C2 Shadow
It was working fine yesterday. When I got home I
Try unplugging refrig for a few min , then plugging back in . This will reset the adaptive timer and at least get the refrig working . The adaptive timer , is located in the control panel . Pt # 4388932 . To replace this board , remove the knobs and pro the top of the panel outwards . Remove the 4 screws holding the panel ( 2 are on the inside by the light bulb ) . You should now have access to the board .
Sep 30, 2009 | Whirlpool ED5VHGXM Side by Side...
New nozzle, plenty of water, but no pressure.
It is warrantied for 1 or 2 years. Low pressure could be due to the un-loader valve needing grease. If it is leaking it will not work properly. If it is stored somewhere cold during winter months the small parts inside will crack.
Sep 18, 2009 | Karcher 2500 PSI Pressure Washer
Blade in my Kitchen Pro 6725 does not turn
You probably need a new belt. Either that or as a result of adverse temperatures in that cabin the motor is gone.
Unfortunately Regal does not make bread machines any more and that belt is very difficult to find.
Maybe if you can measure it you an find something close.
What a pity...
Hank
Sep 03, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My husband forgot to winterize our Kenmore Elite H3 washer when we moved. It was stored in our garage for 5 months(September - February). When we hooked it up water immediately started pouring from the...
Its most likely the rubber tubing, and sack that connect the drum to the drain pump. You can either remove the back panel, or the panel in the bottom front of your washer to check for cracks in the rubber. It might be as simple as the tube came out of place during the move.
Mar 13, 2009 | Washing Machines
B&D battery lawn mower - winter care
Hi, it depends on the age of the battery. if it's new no ploblem depending on the age you may have to give it a trickle charge in jan.
If this doesn’t work for you please write back. Thanks,
Nov 19, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
95 people viewed this question
Top VIA Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a VIA Garden Expert? Answer questions, earn points and help others
