Question about Dell Dimension 2400 PC Desktop
SHOULD THE CPU COOLING FAN ON A DELL DEMENSION 2400 DESKTOP RUN ALL THE TIME?
    President:
  • 739 Answers
Yes. unless the cpu unit is turn off
Posted on Mar 22, 2011
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 fan replacement
it is very easy just remove the plastic cover from the fan & lose the screw and replace the fan with the new one
Feb 27, 2012 | Dell Dimension 2400 PC Desktop
I change the cooling fan but still hear a crazy noise. Can I remove the cooling fan completely and START my computer just to try to find out where the noise is coming from. Or it's too risky.
Depends which cooling fan you are talking about. As long as you are not talking about the fan mounted on top of the heat sink on top of your CPU then you should have no problem.
Do NOT run graphic intensive software or games as these can dramatically increase heat output (until you put your fan back in)
** If you find this information helpful please leave feedback to help us help others **
Feb 19, 2011 | Dell Dimension 2400 PC Desktop
My Dell Demension 2300 will not power up.
open cpu cabinet then refix RAM.
Reattch all connection to motherbord also check your smps power unit works fine.
may be your smps is gone .
SMPS is aquare box which with you connect power code.
Jul 29, 2009 | Dell Dimension 2300 PC Desktop
HOW IS THE WIRING SET UP IN MY DELL DEMENSION 2400 DESK TOP// I AM TRYING TO PUT BACK TOGETHER THE IINSIDE OF THE TOWER NOT SURE HOW IT IS SUPPOSE TO LOOK
Most of the connections only fit in one place ...
Here is the Service Manaul for the 2400 Dimension.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Jun 13, 2009 | Dell Dimension 2400 PC Desktop
Screen freezes often
check the CPU fan if it is working fine
clean the dust on cpu fan
try cleaning the ram
after trying all above then also if u face the same problem try checking the power supply connectors which connect your motherboard
and the last 2 options will be your motherboard or processor
Dec 27, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Dec 20, 2008 | Dell Dimension 2400 PC Desktop
I have a Dell Demension 2350 tower stuck in DOS safe mode.
restart the system by pressing the power button for 5 to 7 sec and hit the del button to enter the setup and load default setup and run an dell diagonastics
Nov 21, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
93 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
