Question about Sony KV-32FS13 TV
Trinitron KV-32FS13 - will not turn on. Screen remains black (not even a hint of an image starting), no broadcast sounds, and a faint clicking sound on a regualar 1.25 second interval. If this has a cheap fix thenI can pay a $5.00 reward.
Coldcut
  • 1554 Answers
SOURCE: sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Posted on Jan 26, 2008
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
Shuttle83
  • 1139 Answers
SOURCE: Sony kv-32fs13 chirps and flashes
Hello 0279737,
This problem is caused by a shorted Horizontal Output Transistor. I would suggest that you have this TV checked by a qualified TV technician. This type of problem requires dealing with dangerous voltages, and repair should only be attempted by a trained technician.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 08, 2009
SOURCE: KV-32FS13, Unable to change channels.
I found online that these televisions have a problem with the button panels shorting out. I pressed all the button on the television; when I would press the buttons, the favorites screen would appear. I'd press it again and it would dissappear. This would work for all the buttons except for the menu and the button below it on the bottom of the T.V. screen. I took off the back of the television and looked at the circuit boards. I removed the wire connector fot the top button panel, from the main circuit board, and op checked to see if the television would change channels with the remote. NOPE. So, my only other option was to pull off the little rectangular buttons from the circuit board for the bottom of the T.V. If it didn't work I was going to throw the T.V. away anyway. I know it sounds crazy, but it worked. I don't know how much it would cost to have someone troubleshoot and replace the pieces, but I'm not worried about it. I can still change the channels with the top buttons and adjust menu options with the remote now. The buttons that didn't work, the menu and *, the piece was corroded. However, just breaking this one off didn't work; I had to break off the piece for the up and down arrows. I'm not a specialist, but it worked for me.
Posted on Jul 11, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
My sony trinitron 32' image flashes off and on but sound is ok and i am not getting a blinking red light error code.Can i fix myself or for cheap?
if you have a soldering iron, just re soldered cold soldered joints at the pin of the components at the main board which may get loose contact.
Jul 22, 2012 | Sony KV-32FS13 TV
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a UK sony trinitron kv-32wf1u with Black Screen
it could be one of the closed-caption settings. make sure the cc is off. if the problem remains, you may have tuner issues.
Jul 31, 2009 | Sony Televison & Video
Sony trinitron kv-32fs13 32''
when the lights flash those are codes that tv repair men have.youd be better off buuying a new tv,they are less than 500.00 nowadays
May 20, 2009 | Televison & Video
Sony trinitron kv-24fv10, image blinking
check the line transistor near the transformer ahaving a long cable going to a tube
Mar 13, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron, no picture, sound works fine.
There are potentially dangerous high voltages present inside the set even when unplugged, so caution is required. That being said, if you can solder, you may be able to resolve this. If the picture returns with movement, it is possible that the problem is poor solder connections. Try removing the back and sliding out the main board. Resolder any connections that appear grasiny or have rings. That may resolve the problem.
Keep us posted.
Dan
Feb 03, 2009 | Sony KV-32FS13 TV
No image onscreen Sony Trinitron model# KV-27S25
Hi
try to connect the Antenna then hearing the sound what comes on..
Thanks!
Oct 24, 2008 | Televison & Video
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony trinitron KV-32FS13
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS13 TV Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
