Question about Intimus 602 SC Shredder
When I put the power button on the yellow and red lights flash. Machine will not work. It is the Intimus 602 Thank you.
Intimus 602. shredder goes about 2 inchs and then goes into reverse and has a flashing red light
Clean the paper shredder teeth and make sure that there is not paper caught in it and try again to shred.
Jun 02, 2017 | Intimus Office Equipment & Supplies
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
Why does my intimus 602 shredder only run in reverse
This applies if Reverse is forward, and forward is running in reverse. If someone worked on it they may have reversed the wires from the motor to the board. There are four wires from the motor, of the four one goes to MZ on the board, another one goes to MV. If you swap these two wires you will be running in the correct direction again.
Aug 14, 2014 | Intimus 602 SC Shredder
Intimus 602 shredder not shredding
Does it run backwards? If it runes in the right direction, it should take paper. You only should use the reverse, when the machine got stuck. But perhaps it now is running back. Or something broke, so the motor is running, but not driving the mechanical parts inside.
Jul 27, 2014 | Intimus 602 CC Shredder
My ps3 will not power up
here is step by step trouble shooting
1) attempt to turn on the ps3
+you will see one of 4 things a green yellow red light
+flashing red light
+green light
+no lights
2) if you see a green yellow red light call sony your system will need service
3) if you see a red flashing light also call sony needs service
4) if the light is green turn off the system and one the light is back to red press and hold the power button for a series of 2 beeps (do not forget the one when you first push the button down) then let go (it might be a video issue)
5) if you still see no video and a green light check the cable you are using and try again on a different tv
6) if you see no power light call sony it needs service
these are genuine trouble shooting steps from sony technical support if you do have to call them be prepared to follow the same steps that lead up to service. thank you
Oct 30, 2011 | Sony Playstation 3 (PS3) Console
No power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
May 24, 2010 | Jet 3 Ultra Power Chair
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Intimus 602 SC Shredder Logo
50 people viewed this question
Top Intimus Office Equipment & Supplies Experts
Lonnie Arks
Lawrence Oravetz
ray gallant
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
