Question about OEM Systems WD 25 SERIAL HD 160GB WD1600BEKT OEM 160 GB SATA Hard Drive
My system does not recognise my LG HXD5 500G HARDDISK
  • 108 Answers
How come that your system does not recognize the disk? what does appeared on your system? please let me know something first.
Posted on Mar 22, 2011
  • must_we_die6 Aug 22, 2011
    same problem here. it just won't recognise it, i plug it in and then nothing happens. it's never been used, i just bought it an hour ago. i'm running windows vista.
  • Jude Jerry
    Jude Jerry Dec 16, 2014
    freak ! ! ! my hard drive ain't working anymore ! !
Harddisk not showing on pc
is the disk backup or in the pc internal hard-disk if external no need software download just get another pc or use recovery software to get your data from it and then format and re backup your data
Jun 27, 2017 | Buffalo Technology DriveStation HD-HC500U2...
WINDOWS SET UP FAILS TO LOCATE THE HARD DRIVE ACESS SEEMS TO BE DENIED
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Andrew.A
Apr 07, 2011 | Maxtor Hard Drive
The machine restart and the harddisk cannot be recognise
Do you mean that the HDD is not detected when you restart your PC?
Is it a New HDD or used HDD? If it is an old HDD probably the HDD have failed.
Is your disk a "SATA OR IDE" interface connection?
Go to your BIOS settings and see whether your HDD is recognised on the BIOS settings.?
Best thing is to go back to your MotherBoard manual and look an the BIOS settings. If you are not sure just use the default settings.
Jun 28, 2010 | Microsoft Windows XP Professional
I have 1 terrabyte external sata harddisk that sometimes is recognised and if its recognised it keeps freezing the computer and at times fails to be recognised. even if i put it directly onto the machine...
Have you tried a registry repair program? Could help, there are a few free ones on download.com website. Also a free one called Advanced System repair which seems to solve many of my problems, also has a registry repair on it.
Hope it helps, just throwing in my 2 cents.
Dec 01, 2009 | Maxtor Hard Drive
Hye..my acer aspire laptop very bad causes of virus infection and mess with all my files and folders. so, it think reformat is the best solution for me. But unlucky, when i restarted my Laptop and install...
Hello !
You have said that you have done installation and Harddisk are not recognised this is a indication of damaged Harddisk ie its registry is bad or its not working .
I recomend a new Harddisk then you will able to use your laptop
Before you change the harddisk you should check the IDE cables by swapping them coz sometimes they could be faulty, connect new cable to the harddisk then on it try installation again .
Good luck
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
My laptop cant find the harddisk
Explain your problem in swedish and i may help you.
you cant format both NTFS and Fat32..its either NTFS or Fat32.
But as i i told you above, explain the problem in swedish and i will try to help you.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
My 160gb and 500gb are not showing on the desk top last night they were there. I hasve done all the simple trouble shooting turning htrem off and on, unpluging the power and firewire cords and rebooting...
Hi Bob,
Just try resetting the BIOS and check if it works.
You need to access BIOS screen and most of the computers has F% key is assigned for Loading the Dedault Settings. After F5 key you need to press the F10 key to save the settings and exit from the BIOS.
Hope this helps!
Pat
Mar 14, 2008 | Computers & Internet
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
OEM Systems WD 25 SERIAL HD 160GB WD1600BEKT OEM 160 GB SATA Hard Drive Logo
981 people viewed this question
Top OEM Systems Computers & Internet Experts
micky dee
Terry Hair
Bill Boyd
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
