Question about Olympia Mastertype 3 Typewriter
Where is the pitck selector? - Olympia Mastertype 3 Typewriter
  • Olympia Master
  • 3,594 Answers
Did I type pitck instead of pitch? On the L. side if the keyboard there is a slide switch labeled 15, 12, 10 and PS.
DickyO
Posted on Mar 22, 2011
The stitch selector keeps turning , doesn't select stitch
1. Check for screws under the selectors outer ring. Tighten if loose
2. Check for loose screws on the front of the selector. The selector switch may have a cover to camouflage the screws. Tighten if loose.
3. If there are no screws the selector may just be pushed on. Pull forward to remove. It is possible the inside metal bracket is stripped from the plastic. Look for looseness of the center bracket.
4. Give the selector a thorough check for cracks. If you find cracks you will have to replace it.
Mar 12, 2015 | Sewing Machines
Why wont my 2001 ford windstar blow out of vents ? only on defrost?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • You probably have a vacuum leak , Pull heater control panel an check for vacuum . A broke vacuum hose or The vacuum selector valve is bad ! Or check for a vacuum hose in the engine compartment being off somewhere !
Mar 08, 2015 | 2001 Ford Windstar
Maruti/ertiga how to set clock.there is no any botton to set the clock
How to set Clock When the ignition switch is in the "ON" position, the display (D) shows the time. 2) To change the hour indication, turn the indicator selector knob (2) left or right repeatedly when the hour indication blinks. To change the hour indication quickly, turn and hold the indicator selector knob (2). To set the hour indi- cation, push the indicator selector knob (2) and the minute indication will blink. 3) To change the minute indication, turn the indicator selector knob (2) left or right repeatedly when the minute indication blinks. To change the minute indication quickly, turn and hold the indicator selector knob (2). To set the minute indication, push the indicator selector knob (2). To change the time indication: 1) Push the trip meter selector knob (1) and the indicator selector knob (2) together. w WARNING If you attempt to adjust the display while driving, you could lose control of the vehicle. Do not attempt to adjust the display while driving.
Hope this helps.
Bob
Feb 08, 2015 | Cars & Trucks
No reverse ranger automatic transmission
Loss of reverse gear in an automatic gearbox
Broken Reverse selector Band
Brake material on Selector band is Worn out
Selector band needs sever adjustment
Selector bands hydraulic piston seal had failed
Selector not getting oil to work the piston.
Apr 03, 2014 | 1998 Ford Ranger SuperCab
Errore f6 lavatrice ariston wmg 923
F06: Selector Error
Overhaul CND (selector connector)
Overhaul Selector Connector
Control Selector/CND Continuity
Control Selector Motor
Replace Selector
Replace Card
Dado
Feb 23, 2014 | Ariston Technologies Ariston AWD12 Front...
How do i reset the time @ date on my fujiT200 camera
Press MENU/OK to bring up the menu. Press selector-left and select the wrench icon. Press selector-right to put the cursor in the Setup menu. Use selector-up/down to select "Date/Time" and press MENU/OK. Use selector-left/right to move between fields, selector-up/down to change them.
If you need a manual, you can download one here.
Oct 10, 2011 | Cameras
Gear shift lever in column is loose
your problem with the gear selector is in the item 25 these are 2 plastic bushings that wear out and cause the gear selector feels loose, you should also check the item 27 this item has one or two screws loose and cause the gear selector feels loose
Item Part Number Description 10 3F609 Tilt Wheel Handle and Shank 11 7361 Column Shift Selector Lever Plunger 12 7210 Gearshift Lever 13 3D657 Steering Column Shaft 14 7B071 Transmission Control Selector Lever Plunger Spring 15 7G357 Gearshift Lever Pin 16 7212 Shift Tube 17 N806582 Tilt Column Pivot Screw 18 7C464 Transmission Control Selector Lever Spring Clip 19 7E400 Gearshift Tube Bushing Clamp 20 - Spacer (Fixed Column) 21 3E729 Steering Shaft (Fixed Column) 22 3F527 Lever Assembly (Manual Transmission) 23 3F530 Pin (Manual Transmission) 24 3F752 Brake Shift Interlock Solenoid 25 7335 Gearshift Lever Socket Bushing 26 7A216 Transmission Shift Selector Position Insert 27 7302 Transmission Selector Lever Arm and Support 28 7E395 Shift Cable and Bracket 29 7210 Gearshift Lever 30 3E691 Steering Column Lock Pawl
Feb 13, 2011 | 1998 Ford Econoline
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Printing incorrect letters
Check the pitck selector slide switch it may be in PS this will give you that problem.
DickyO
Apr 06, 2009 | Olympia Mastertype 3 Typewriter
Shifter indicator light
is this the shift position indicator like drive, park reverse, neutral?
Transmission Selector Lever Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the heat shield.
  1. Disconnect the selector lever assembly.
    1. Disconnect the selector cable adjusting cap.
    1. Disconnect the selector cable.
    1. Remove the nuts.
  1. Lower the vehicle.
  1. Remove the selector lever assembly.
    1. Remove the cover.
    1. Lift out the selector lever assembly.
    1. Disconnect the selector lever electrical connector.
Oct 20, 2008 | 1999 Mercury Cougar
Olympia Mastertype 3 Typewriter Logo
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
