Question about La Crosse Technology E. Howard Ambassador Radio Controlled watch
Can you send me instructions on how to set the time and date on my boss's E. Howard & Co. accurate radio controlled watch? Thanks!
    President:
  • 2,501 Answers
The maker claims setting to be automatic!
The signals for Casio watches are sent out during the night, so I would assume that your watch will be the same.
Do nothing and wait till tommorow!
If nothing happens, then go to http://www.lacrossetechnology.com/support/manuals.php and select the manual from the list.
Posted on Mar 22, 2011
How do I adjust the time zone on my E.Howard atomic watch? The T2 button doesn't activate anything when it's pushed?
No, just set properly. This watch is very difficult to set. A watchmaker may be able to help you. The instructions are not very clear. You might try a watchmaker for assistance or try calling them although I have not had much luck along those lines.
Dec 28, 2011 | La Crosse Technology E. Howard Ambassador...
I have a Casio Wave Captor 4757 WVQ-142E and after the change in time this fall I can't seem to set the time correctly. I am in Paris, so GMT +1, however it is 10:30 and my watch reads 3:03. I have reset...
I sympathize, it took me ages to work this out - I had the same problem having had the battery replaced in my watch which only lasted 18 months...the irony was that my previous watch was still working & set to the correct, time date etc!
The following instructions are for the Casio Wave Ceptor 4757 WVQ-142E, the official Casio instructions are available at the following:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4757
For the extra information Casio neglect to tell you in the manual, read the following:
First, the watch needs resetting. To do this you need a watchmaker's screwdriver, remove the back (4 screws - obviously, you do this at your own risk), remove the thin plastic cover to reveal the battery.
On my watch on the battery cover it says to reset the watch, get a pair of tweezers & connect the battery back to the negative (marked -) plate for about 2 seconds, thus forming a circuit.
The watch stops, the screen goes blank for about 30 seconds, replace the plastic cover , back & screws.
Wait until the watch has picked up the correct time signal, the digital part will show the correct local time, the analogue screen won't at this stage.
Set the watch to the desired time zone that you require or HS (Home Setting).
Then press button "C" (bottom left) to scroll through until "HS" is displayed on the screen, then press button B (top right) for about 5 seconds until it flashes "OO" in the screen, then press the A (top left) button down & to reset the analogue time (so all 3 hands are pointing up) to 12 O'clock, it has to be set to 12 so the watch will recalibrate itself, if it is not set to 12 O'clock, it won't work! - sadly Casio don't tell you this bit in the manual....& of course this is really obvious to us mere mortals!
Now that you have aching hands & repetitive strain injury, press the B button (top left) to exit the (watch) hand setting mode & the watch will now wind the hands by itself to the correct analogue time, (or in theory it will, it took three attempts to set my watch).
Yes, for the record Mr Casio, if you hand a watch to someone & tell them to set it to the correct time, they will set it to the current local time (assuming that it is not 12 O'clock) & as opposed to 12 O'clock by default!
This is not rocket science, if your company is able to make & market a radio controlled watch which is in theory accurate to one second in a million years because it is controlled by the Rugby atomic clock, you'd think that the instruction department could write some decent instructions!
Hopefully this solved the problem!
Nov 02, 2010 | Watches
I have a E. Howard Accurate Radio Controlled Time & Date watch and it has the wrong time. I would like to set it but I do not have the instruction.
Try the site below for instructions. However, after resetting my watch, with the same problem, it still is running 2 minutes slow.
http://www.lacrossetechnology.com/ehow23/manual.pdf
Jul 23, 2010 | Watches
Had new battery installed in Howard wrist watch, cannot get the correct time. The date is correct.
You don't say which model you have but if it is a radio controlled watch, then try re-setting the location, it frobably "forgot" where it is and wen back to the original factory setting.
Jul 17, 2010 | Watches
Defective E. Howard & Co. radio-controlled watch
ok place watch on window ledge inside house ..when you go to bed make sure its sat on a book with nothing else in its way except the glass window, the signal should be picked up by your watch between midnite and 3am that is sent from one of 5 world wide beacons.if this does not work have battery refitted and make sure the repairer AC's the watch this has to be done any repairer will know what you mean..
Mar 24, 2010 | Watches
I need a user guide for a La Crosse WS-9211 Weather Station clock
Solved it! La Crosse let you download manuals from their website.
Nov 23, 2008 | La Crosse Technology E. Howard Ambassador...
Instructions for a mens FESTINA Watch 16095
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solve
May 08, 2008 | La Crosse Technology E. Howard Ambassador...
La Crosse Technology E. Howard Ambassador Radio Controlled watch Logo
373 people viewed this question
Top La Crosse Watches Experts
Starnley Johnwells
Starnley Johnwells
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
