If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
The screen sensor board might be bad and need to be replaced. If you cannot touch anything on the screen then you have to replace the sensor board, but if you can touch the screen but it is too hard to select any option, then it means you have to calibrate the screen to be able to enjoy it once again.
To calibrate the screen, go to the phones menu, then you select the settings, then you select calibrate screen, then you touch the middle of the star that appears on the screen, After that the screen will be able to work fine again.
Hope this information helped.
Here is a link for the guide on taking apart the Samsung F480 Tocco. This will show you how to replace the lcd screen and provides links to purchase a new screen as well.
