Question about Motorola MH230R Two Way Radio
The two radios can not communicate with eachother. Set on '10' and '6', but when I scan the channels, the radios do not stop on the channel I have them set on.
bastardon7
SOURCE: don't communicate
Thank you very much for the tip. It was help ful
Posted on Feb 25, 2007
Benimur
  • 6966 Answers
SOURCE: i have a problem
Normally in a Motorola T5700, to set a specific channel to monitor (and reply to) called your working channel, you press the Menu (center) button and the current channel shown in the display will flash. Press either the + or - buttons to change to your desired channel number which should be identical to both radios. Press the PTT button to save.
Likewise, both radios must have identical Interference Eliminator Code. To set code, press Menu till the code display blinks. Press + or - to select code. Press the PTT to save. To disable the code, select 0.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 22, 2008
eradiostore
  • 1654 Answers
SOURCE: change scanning feature for different channels
When having the radio programmed indicate to the programmer which channels you would like to have in a specific scan group. They an at that time set up a particular group for you.
Posted on Jun 26, 2008
eradiostore
  • 1654 Answers
SOURCE: how to set the new channel you wnat on the avx5100 radio
Here is a link to the user manual: http://www.123radios.com/Manuals/AXSeriesManual.pdf. Programming is explained on page 2.
Posted on Dec 17, 2008
eradiostore
  • 1654 Answers
SOURCE: I want to communicate from t5720 talkabout to midland lxt303
Set your interference eliminator code on the T5720 and the Qt filter both to zero. You have one or both turned on. By setting them to zero you will turn them off. Then your radios should work together.
Posted on Mar 14, 2009
My maycom scanner is stopping on a frequency,scans etc but no talking.?
Scanning may stop on channels with a carrier but no modulation (annoying) or channels where access is controlled by a code or channels arranged in talkgroups.
Feb 12, 2017 | Radio Communications
Weather chanel comes in costanty
Cannot have a regularly scanned channel be a weather channel. press 'manual' on the WX channel, then press the 'L/O' "lockout" button and it will keep the WX channel out of the scan.
Feb 26, 2014 | Radio Shack Pro-2018 Scanner
One radio clicks when the other is mic
Scanning is interrupted when you key the other unit's mike. For example, if the non-scanning unit is set to channel 13 and keyed scanning will stop at channel 13 on the other unit to establish communication between the two.
Nov 07, 2013 | Midland LXT310 2-Way Radio
Don't talk to each other
What channel do you have to listen to the weather
Mar 10, 2013 | Motorola T8500 Two Way Radio
I took out the rechargeable batteries (replaced with regular AAA)in my Uniden walkie talkies and now one is set for channel 19 and one for channel 6 so they cannot communicate. How do I set the channels...
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Aug 06, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Channel scanning fucntion won't work on my new Oregon Scientific TP329 Two Way Radio. Keeps scanning without finding a valid signal. The radio works when I set the channel randomly but so far I can't find...
Make sure there is a transmitter "on" somewhere along the way, otherwise it would not stop scanning. Try keeping the PTT pushed on the other set whilst you scan.
Jul 10, 2010 | Oregon Scientific TP329 Two Way Radio
I haven't used my Bellsouth model 1008 two way radios for a long time....I just replace the batteries and turned them on but they are not in sink with eachother. How do I get them to transmit and receive...
Sanity check. Make sure the radios are on the same channel. They shouldn't have to be "sync'd" The channel freqs are all hard set and can't be changed to my knowledge.
Apr 25, 2009 | BellSouth Bell South (1008RD) 14 Channel...
No audio but transmits ok
Hello dgbuhl,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a Privacy Code or Quiet Code. The actual name of the feature may vary.)
In order for your radios to communicate with eachother all of the radios need to be on the same channel and have the same CTCSS / Privacy Code programmed (or the CTCSS feature must be disabled on all the radios). If CTCSS is enabled on one of the radios, but not the other, the situation you describe would occur.
Check your user's manual for more information on the Privacy Tones and how to set them.
Best Regards,
Ken
Go Ahead. Use Us.
May 12, 2008 | Cherokee FR-465 (14 Channels) 2-Way Radio
I have a problem
Jan 22, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Uniden GMR1448-2CK
sounds like you have one units side channels set diffrent than the other.you should be able to reset this by reverseing the battries in both units for a few moments then replacing them correctly. or remove battries for 24 hours or more to delete memory
Dec 09, 2007 | Uniden GMR638-2CK (22 Channels) 2-Way...
Motorola MH230R  Two Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
