Question about Sony Cyber-Shot DSC-P73 Digital Camera
Need to periodically replace good batteries to make camera work.
    Problem Solver:
  • 53 Answers
Try to use Good Brand Rechargeable batteries 2600 MHz / above. Remove batteries after use. only using time place the batteries.
Posted on Mar 22, 2011
The camera says that the batteries are too low to take pictures. Even when known good batteries are installed the same message comes up. Any ideas?
Hi
Give the batteries and contacts a good cleaning with a Q-tip moistened with rubbing alcohol.
It worked for me.
Hope this helps you out.
-Steve
Mar 18, 2015 | HP Photosmart M537 Digital Camera
Dsc60 battery drains quickly
First of all, you need to use alkaline batteries with you camera, if you use mercury ones they wont last long.
Mar 14, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
My batteries seem to need replaced quite often. Should I use a special brand
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power.
Jan 03, 2015 | Kodak EasyShare C875 Digital Camera
Won't turn on
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery.
If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Jan 21, 2014 | Nikon COOLPIX L810
No coming on when battery installed
Jan 09, 2014 | Canon IXUS 80 IS Digital Camera
D1oo Nikon enel3 lithium Battery packs stopped working
Batteries don't live forever. When handling them correct they can survive 1000 charge and discharge cycles. When taking an average of 200 pictures per charge, the battery could survive the camera shutter.
Try to use a battery till it is almost empty. The camera will give a warning when you need to replace (or charge) the battery. When you want to go on a trip or need to make a series of foot's you should take only charged batteries. When you don't use a camera, for a longer period, don't leave the battery in the camera. It could start leaking and damage the camera. But when the battery was not used for a longer period, please charge it before using it again.
This could help you to keep your batteries in better condition and let them live longer.
Dec 06, 2012 | Nikon ENEL3 Lithium Ion Battery Pack
Handycam not holding charge even with new battery.
Sometimes the batteries will build up a memory if they are only used for short periods of time and never used to the point of going completely dead, so possibly getting a new battery online. B&H photo is a pretty good site.
I know some chargers have an output to the cameras battery connector that powers the camera, and if that is plugged into the charger it will not charge the battery simultaneously.
If the camera is working when plugged into the power source it usually turns out to be a battery problem. Sadly the only choice it to buy a new battery.
Feb 29, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Won't work
Are you sure the battery is charged ? i have seen many Casios that do not recharge fully if the camera is left for long periods with the battery flat - the battery goes below the 'float' level and the charger does not work. See if you can borrow another battery or use a generic charger that does not look at the battery level. A good camera shop should be able to help.
Jun 09, 2010 | Casio Exilim EXZ75 Digital Camera
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
32 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
