Question about Whirlpool Refrigerators
Refrigerator Whirlpool model GD25BFCHB00 not working - no power to compressor. Note this is an electronic controled model. How can I determine what part is required?
    Problem Solver:
  • 53 Answers
May be timer problem. Rotate the timer manually (Back side of the refrigerator / bottom Near the compressor / inside the freezer) Refer diagram. Rotate then working... Problem Timer / Heater protector .. replace (inside of the freezer)
Posted on Mar 22, 2011
Whirlpool Gold Side by Side refrigerator GSS26C4XX, how to force the defrost?
With the bottom kick panel removed, look for a defrost timer. It will look like a small motor and have a slotted fitting on the end of the shaft - usually you can turn it only one way. With the unit running, slowly rotate the timer shaft 'till the compressor stops. That's the beginning of the defrost cycle, which will end when the timer makes a full revolution. It's usually 12 or 24 hours between defrost cycles.
If the box is completely electronically controlled (electronic logic board), you may not find a mechanical defrost timer.
Aug 03, 2017 | Whirlpool Refrigerators
My Estate Whirlpool side by side Refigerator does not come on. The lights work, but nothing else. What could be the problem?
The first place I would look is the thermostat. After that it could be in a defrost cycle and will come on in about a half hour. Last thing it may have an electronic control that could be bad.
Sep 23, 2014 | Whirlpool Refrigerator Compressor 8201555
COMPRESSOR RUNS A LOT
Your model has a mechanical thermostat inside the control panel. I believe you have something else going on like a bad fan, start relay, capacitor. Something is causing the compressor to struggle to keep up and in turn causing the compressor to short cycle. If the thermostat has no control over run time then something like I explained is causing the problem. Here is a parts manual=> ED5VHEXVB04 Contact me if you would like my help, Thanks Sea Breeze
Feb 26, 2013 | Whirlpool Refrigerators
Whirlpool top freezer fan not runnning and no voltage to the fan with the compressor running
This refrigerator has a basic wiring diagram showing power going through the defrost timer, compressor and compressor start components. Because the model number could be very close to the ET8WTKXK your model may have either a ADC, adaptive defrost control or typical 482493 Defrost Timer
Here is a Whirlpool ET8WTKXK Top Freezer Refrigerator basic wiring diagram.
sea_breeze_121.jpg In this photo you may have bad contacts inside timer part 4 in photo=> ET8WTKXKB03 Controls Ethier way I don't think it will be hard to find, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool ET8WTKXK Top Freezer...
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
Refrigrator will not get cold
replace the control board in rear of unit $80.25
Oct 18, 2009 | Whirlpool Refrigerators
Whirlpool Conquest Gold White Model# - GS6SHAXLQ03
The relay is the start device,but you need to determine if you need it,try to see if you have power to the compressor,is the compressor running,is the condenser fan motor running,is the coil under the unit clogged with dust,if the fan under the unit doesn't run it will overheat the compressor and it will go off. and if the coil is clogged the same thing goes.
 Usually if the relay is bad the compressor will make a hum and a click noise but will not actually run.about every 5 minutes..
Sep 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Defrost timer
most newer refers have the timer located somewhere near the main controls. Usually in the console near the refrigerator thermostat. older models could be behind the kick plate on the bottom or even on some in the back near the compressor. If it's a new electronic model it may not have a timer.
Apr 22, 2008 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
