Question about Roper RAX7244KQ Top Load Washer
WASHER WILL FILL UP BUT WONT DO ANY THING ELSE IT CLICKS THEN MAKES A BUZZING SOUND AFTER IT FILLLS
    Sergeant:
    Champion:
  • 202 Answers
Sounds you you have a wire off the capacitor or capaciter is bad by the motor..... or the motor is bad
Posted on Mar 22, 2011
Washer will not start. it makes a slight buzzing sound and then nothing.
OK buzzing sound, hmmm, need to know more than that, dos the water fill ??,,if not disconnect the water hoses at the machine and check the filter elements in the intake water side they might be plugged, if the unit fills with water then the starter capacitor at the motor might be defective. good luck
Jun 01, 2012 | Maytag Washing Machines
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Won't start
you have a bad solenoid battery or starter try to ground the starter touch positive to groundwith a rubber ended screw driver if the starter spins you have a bad solenoid
Jun 22, 2009 | 2003 Yamaha YZ 250 F
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Wont spin
WHEN YOU SAY IT MAKES A BUZZING SOUND DOES THE DRUM TRY TO TURN.MOHAMED
Sep 16, 2008 | Washing Machines
Whirlpool dishwasher
It sounds as if your motor is locking up. Check under the front lower panel, snd see if there is water leaking into the motor, the motor simply seizes, and needs aspot of grease. You may also need to reprime the washer. To prime, Slowly advance the timer at start-up, After a few clicks, you will here the water valve open and start to fill the tub, then let the washer do it's thing.
Jul 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Dec 26, 2007 | Washing Machines
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Roper RAX7244KQ Top Load Washer Logo
52 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
