Question about Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher
The door is getting rusty. I believed that stainless steal didn't rust. Is there a way I can remove the spots?
    Champion:
  • 246 Answers
I am not sure about how to remove the rust spots but to recover your appliance without replacing it then check out www.applianceart.com
They have selections to recover your dishwasher including real and faux stainless options to have your existing appliances looking new in a flash. These guys are worth checking out.
Posted on Mar 29, 2011
  • Jenn-Air Master
  • 3,247 Answers
Normally these appliances use brushed steel which gives a stainless steel look.
Get a magnet and run it on the sheet. If it sticks then it definitely is not stainless steel.
However, with wear and tear stainless steel surface does break down causing rust to start.
To remove rust go to this site.
Posted on Mar 22, 2011
  • Geoff White
    Geoff White Feb 16, 2016
    There is in fact a type of genuine stainless steel which is magnetic (martensitic stainless).
    The problem is more one with low-grade stainless which is easier to form into the necessary shapes, but which can spot rust. Obtain a bottle of dilute phosphoric acid solution from a pool shop (chlorinator cell cleaner). Pour a small amount of this in a plastic dish. Wear eye protection and rubber gloves, and use this acid to scrub the rust. Leave it for 15 min then rinse off. The acid will passivate and convert the rust spot so it does not spread.
I have faberware stainless steel knife set knives have rust spots. What & why??
How do remove rust spots from stainless steel Yahoo Answers
Yes, stainless will rust. The above link has helpful information on how to treat rust spots on stainless. The web site suggests using a mild acid, such as oxalic acid, which can be purchased at Home Depot or Lowes. Use a green scrub pad, as recommended. Hope this helps....
Apr 28, 2014 | Refrigerators
Can stainless steel rust?
Unfortunately yes, any stainless steel product can get rusty under some circumstances although a stainless steel is much more resistant to corrosion and rust. I suggest you to get stainless steel if you don't want to replace your silverware and kitchen product every couple of months.
Jul 25, 2012 | Camping, Backpacking & Hiking
Rust spots appearing on the front doors of my Bosch refrigerator
Stainless steel does rust - or at least that is the theory.
There is in fact two types of stainless steel; the original categorised austenitic which is instantly recognised due to it being unable to attract a magnet due to the absence of iron. Austenitic is relatively expensive and difficult to work but adding iron in various quantities to the alloy produces a cheaper, lighter metal that looks good and is easier to work while still providing some resistance to corrosion. The more iron that is added to the ferritic type of stainless, the lighter, cheaper and easier it is to work but the corrosion resistance is substantially reduced.
Cars have been fitted with stainless steel exhaust systems of the ferritic type for many years and although they last a long time they soon show surface rust and sometimes will rust through.
I expect your fridge wipes are either acid or alkaline that are suitable only for austenitic and good grades of ferritic and Bosch have used a particularly poor grade of stainless. I expect fridge magnets stick very well...
Mild discolouration could be removed with a mild abrasive cleaner though that would tend to ruin the brushed finish. Clearly future cleaning should be carried out with a neutral ph cleaner and the surface protected with a hard wax polish.
I suggest you check the cleaning instructions in the Bosch instruction book. If you feel you have done nothing wrong you might be able to claim from your household insurer as accidental damage. It would be a good idea to inform the manufacturer of the cleaning wipes...
May 27, 2017 | Bosch B26FT70SNS
How do I clean a rusty hopper for a meat grinder? It has been neglected and i would like to use it in a meatshop if i can get it clean. It is galvanized ,the gard is clean but the pan is rusty. I tried a...
This happened to me:
I used a gel rust remover with an electric pad sander (3 times - with a medium course paper the first 2 times, and then a finer course paper the 3rd time). It smoothed and cleaned it up pretty darn good, but there was still a slight red discoloration to the metal. So, we just kind of line the hopper with heavy duty aluminum foil and line over that with 2 clean plastic food grade bags. Also, now as part of maintenance/cleaning after use, we use a little spray rust remover at the beginning of the cleaning process. This should help prevent any more rust and might even help dull that red discoloration after a while.
Good luck.
Jan 17, 2018 | Hobart Kitchen Ranges
Rust on freezer door side by side
it might not be rust,
give this a try,
find a small spot and wash it with cerramabryte, is a glas top cleaner, i cleaned many many units this way
after you scrub the spot polish it with stainless cleaner
Oct 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Rust on stainless steel
1) Take rust off with Bar Keeper's Friend and a damp sponge.
2) Rinse and dry
3) Wipe with mineral oil.
Will be good as new
Sep 24, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
Rust spots on Bosch STAINLESS dishwasher
Debruce Polish is the answer. It is non-toxic and odorless, DeBruce will remove the rust and pacify the finish. DeBruce is perfect for touch ups and great on ceramic cook tops and more. We buy DeBruce polish at debrucepolish.com.
Jul 28, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Rust spots on Bosch door panel (1 year old)
I have same problem, low grade stainless will rust, could be the problem
Feb 25, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Surface rust on GE Profile Stainless Steel Refrigerator
We use DeBruce Polish on all of our stainless steel IT IS THE BEST and it is ECO_FRIENDLY! Ceramic cook tops-kitchens in all our properties, DeBruce Polish does the job, never anything else just do the touch ups-seriously just the spot!!!
Better than Bug Be Gone on our windshields we travel with it-use on polished marble, granite also. We find DeBruce Polish at debrucepolish.com
Nov 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher Logo
343 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
