SOURCE: Ice crusher don't work
Hi, It sounds like the selonoid that shifts the auger is not working. This part is located behind the panel that the bucket pushes against. The little wire arm on the bucket goes into this. Sometimes they just get froze up from the moister. If you remove the panel/section the selonoid is in, you can see if the part has went bad.
I hope this helps you. Please let me know If I can assist you further.
Vic
SOURCE: Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
SOURCE: ice crusher not working
Remove the ice tray and check to make sure that it is not froze up with with ice. the bottom of the tray has a rod attached to it that controls a flapper that opens and closes to allow the ice to pass thru without hitting the cutter or closes to hit crush blades. make sure this is not in a bind or froze up. this rod goes into a plastic housing at the back of the freezer that has a solenoid switch that activates it to open it up. check to make sure all of these items are free of ice and in their proper position and or not broken.
